CON vs. =
Results 1 to 7 of 7
Thread: CON vs. =
    Sep 2010
    Las Vegas, NV
    Default CON vs. =
    Is there any difference or advantage to declaring a constant using CON vs. using an = sign to assign a variable value? i.e
    widget CON 155 vs. widget = 155
    Using just the = sign would require declaring the value beforehand and maybe use another few bits of memory. Beyond that is there any other disadvantage?
    Dec 2012
    Tennessee
    Default Re: CON vs. =
    if you dont use it that way it will be like this
    widget VAR Byte
    widget = 155
    and there is a possibility if your program is large that you might change widget = ?? something else later in your program
    also say you want to tell widget that it is 25000 halfway into your program, but you only delared it as a byte, so it will
    generate an error. but if you use CON then hey it auto sets the Variable size
    May 2007
    Look into the differences between constants and variables.
    Sep 2010
    Las Vegas, NV
    Well, when I didn't define the question correctly I got what I asked for. What I should have asked was, do both constants and variables use up memory or resources when programs compile or execute?
    According to what I've read in the PBP3 manual, the answer for constants is they don't use memory of the micro-controller. They make substitutions during compile which I would assume uses less program bits.
    Variables do use memory and depending how they are defined they can use a goodly portion. I assume that if a variable is defined as a word and you're only using a few bits you'd be wasting space. Better off defining it as a byte or using a small routine to store those bits as part of a larger word/byte. So if you're trying to save memory for other things, and your variable doesn't need to change, then defining it as a constant would free up RAM to be used elsewhere.
    I've yet to write a program where I'm concerned about memory but I figure I'd start with good habits. Especially ones that let me program more efficiently.
    Thanks for making me read the manual. It really is a wealth of info.
    May 2006
    Del Rio, TX, USA
    So, if I understand the question, “Is there a difference between the following code snippets?”
    MyByte VAR BYTE
    MyByte = 155
    MyByte VAR BYTE
    MyCon CON 155
    MyByte = MyCon
    The answer is: No.
    The only difference is how you read it as a human. For the PIC and it’s code, they are exactly the same.
    Sep 2010
    Las Vegas, NV
    I agree but both of the examples use some of the PICs RAM where declaring MYCON CON 155 only would not.
    At least that is my understanding.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by AvionicsMaster1 View Post
    You are correct, constants use no RAM, but variables use RAM space depenedent on their type.
