LED PWM with High Frequencies?
Results 1 to 4 of 4
    Default Re: LED PWM with High Frequencies?
    Thanks wdmagic.
    Seems like trying to add PWM on ECCP1 is throwing a wrench into the existing motor speed control - the motor just turns 'on' (without ramping up) and the LEDs connect to RC5 are unlit. Is it because ECCP1 is taking control of some pins I'm already using? I think maybe there are additional registers/config I need to set in order to get a single PWM output on RC5.
    ' Pin Connections
    ' RA0                       -> B pin of rotary encoder
    ' RA1                       -> A pin of rotary encoder
    ' RA2/CCP3                  -> Stbd motor PWM output (motor 1)
    ' RA3/MCLR                  -> Button switch pin of rotary encoder
    ' RA5/CCP2                  -> PWM for flashing LEDs ?
    ' RC0                       -> Stbd motor direction signal (motor 1)
    ' RC1/CCP4                  -> Port motor PWM output (motor 2)
    ' RC2                       -> Port motor direction signal (motor 2)
    ' RC4                       -> Serial output (Tx)
    ' RC5/CCP1                  -> PWM for steady-on amber LEDs
                                ; This is also the only available Rx pin, so this might not work
                                ; with plan to have 1 knob to control them all
    DEFINE OSC 16               ; Set oscillator 16Mhz
    OSCCON   = %01111000        ' 16MHz internal osc
    ANSELA    = 0               ; Digital only for all PortA pins
    ANSELC    = 0               ; Diginal only for all PortC pins
    TRISA     = %00001011       ' Make PORTA pins 0-1 input for rotary encoder,
                                ' pin 3 for rotary button
    TRISC     = 0
    i              VAR BYTE
    MOTOR_1_DIR    VAR PORTC.0   ' Alias PORTC.0 as "MOTOR_1_DIR"
    MOTOR_1_PWM    VAR PORTA.2   ' Alias PORTQ.2 as "MOTOR_1_PWM"
    MOTOR_2_DIR    VAR PORTC.2   ' Alias PORTC.2 as "MOTOR_2_DIR"
    MOTOR_2_PWM    VAR PORTC.1   ' Alias PORTC.1 as "MOTOR_2_PWM"
    ButtonPress    VAR PORTA.3   ' Alias PORTA.3 as "ButtonPress"
    ' Set up registers for PWM on CCP3, CCP4 & CCP1, CCP2
    CCP3CON = %00001100         ; Use CCP3 in PWM mode (Motor 1)
    CCP4CON = %00001100         ; Use CCP4 in PWM mode (Motor 2)
    CCP1CON = %00001111         ; Use CCP1 in PWM mode (PWM for steady-on engine LEDs)
    ;CCP2CON = %00001100         ; Use CCP2 in PWM mode (PWM for blinking engine LEDs)
    CCPTMRS = %00000000         ; Use Timer2 for all CCPs
    T2CON   = %00000101         ; Timer2 on with 1:4 prescaler
    PR2     = 62                ; For 16Mhz OSC the desired output freq of 15,873Hz is
                                ; achieved with this PR2 value (8-bit resolution
                                ; with 1:4 prescaler)
                                ; PWM freq must be ~ 16-20kHz to reduce noise
    PreSpinVal  CON 17          ; Value to subtract from MinDuty for motor spin up
    MinDuty     CON 75          ; 75 when max duty = 250 (8-bit resolution)
    ;SpinUpPause CON 17          ; Pause during motor spin up
    SpinUpPause CON 7           ; Pause during motor spin up
    MaxDuty     VAR WORD        ; According to Darrel Taylor:
                                ;   MaxDuty = (PR2 + 1) * 4
    MaxDuty = (PR2 + 1) * 4     ; 252 but with prescaler resolution it's actually 250
    DutyVar3    VAR WORD        ; temp variable to store duty variable for CCP3
    DutyVar4    VAR WORD        ; temp variable to store duty variable for CCP4
    DutyVar1    VAR WORD        ; temp variable to story duty variable for CCP1
    FOR i = 0 to MaxDuty
        IF i <= MotorRPM THEN
            ; Spin up motors but only until saved value of MotorRPM is reached
            DutyVar3  = i
            IF PortEngDir = 0 THEN
                DutyVar4 = i              ' Port engine (CCP4), fwd (CCW)
                DutyVar4 = (MaxDuty - I)  ' Port engine (CCP4), rev (CW)
            CCP3CON.4 = DutyVar3.0
            CCP3CON.5 = DutyVar3.1
            CCPR3L    = DutyVar3 >> 2
            CCP4CON.4 = DutyVar4.0
            CCP4CON.5 = DutyVar4.1
            CCPR4L    = DutyVar4 >> 2
        IF i <= StdyOnLEDs THEN
            ; Fade in steady-on LEDs but only until saved value of StdyOnLEDs is reached
            DutyVar1 = i
            CCP1CON.4 = DutyVar1.0
            CCP1CON.5 = DutyVar1.1
            CCPR1L    = DutyVar1 >> 2
        pause SpinUpPause
    NEXT i
    How do I get just a single PWM on RC5 without affecting any other port pins?
    Dec 2012
    Tennessee
    Sorry I cant help you with that, I dont use that particular chip, and your using a bit of code that im unfamiliar with. Im used to only having 2 pwms, and using the hpwm command to output my signal.
  1. Replies: 1
    Last Post: - 4th March 2013, 22:57
  2. Replies: 5
    Last Post: - 26th December 2012, 06:00
  3. Scrolling LED Badge Hack
    By ozarkshermit in forum Code Examples
    Last Post: - 23rd December 2012, 14:10
  4. One of 33 LED output Indicator
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 5th December 2012, 18:26
