VDIP1 and 16f688 HSEROUT
Results 1 to 4 of 4
    Dec 2010
    Default Re: VDIP1 and 16f688 HSEROUT
    here are the datasheets for the 16f688, VDIP1, and the command codes for the VDIP1:
    16f688 datasheet - http://ww1.microchip.com/downloads/e...doc/41203d.pdf
    VDIP1 datasheet - http://www.ftdichip.com/Support/Docu...s/DS_VDIP1.pdf
    VDIP1 commands - http://www.ftdichip.com/Firmware/Pre...mware_V205.pdf
    Your HSER defines are setup for 9600 baud at 20Mhz.
    But you don't have a DEFINE OSC statement, so PBP assumes you are running at 4Mhz.
    What frequency is your oscillator?
    Dec 2010
    wow I sure missed that. I typically use the 8MHz internal oscillator because I have no external crystals to use.
  1. VDIP1 Command List
    By emerson in forum Documentation
    Last Post: - 5th October 2013, 11:55
  2. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 20th August 2013, 14:51
  3. Vdip1
    By sky071022 in forum Off Topic
    Last Post: - 9th March 2009, 04:42
  4. PIC interfacing with FTDI's VDIP1
    By Vidya in forum mel PIC BASIC Pro
    Last Post: - 12th May 2008, 18:02
  5. Problem with 16F688 and Hserout
    By DWV in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 06:37
