what is the bit instruction to get to LCD line2
Results 1 to 9 of 9
    Dec 2003
    Wichita KS
    Hello Edward,
    Edward>>i havent tried it yet but i think you are correct. yes dwayne i im doing "custom" lcd routines, great memory my man.
    thats why i cant use the lcdout function.
    what manual? i have the hd44780 commands sheet, i was having trouble interprting what the command actualy did, i also went to like 5 different webpages i found listed through out this forum to try and find a laymans description of what setting the dd reisters and stuff actually does<<
    I understand why it can be very confusing... Since you are not using the LCDout, you have no "Manual" to go by... Thus, it CAN be very confusing. But!!! the LCD commands (which you probably didn't know) are almost exactly like the LCDout commands in the PBP manual that Melabs puts out. The only thing that will be different, is if you write to the interal memory, or something out of the ordinary. But simple LCDout commands will work without the LCDout... just make sure you have the Data/Command switch in the right place.... Most of the time it is in Data mode... So that you will write DATA out to your LCD for display. The only time it is in Command mode would be switching LCD lines, or Clearing the LCD display with a Dec 1. (Dec 13 will turn on and clear your display). I also understand on the interpreting the commands!...If you want, I have a site someplace that does a great job of telling all the commands of the LCD...in Command mode. I will look it up, if you would like me to, and give you the URL.
    Dwayne (congradulations on your project.)
    Ability to Fly:
    Pilots that are Flying:
    Wink
    Hi, Edward
    I'm sorry for my mistake : your question was nos so clear, as it was not a PBP Background ... I always think we are on a PBP Forum ...
    Yes, I become a bit angry these times : reading here pages and pages of code with the same questions : where is my error or ( can you ) do it for me ??? or ground level Questions showing the manual ( humour ...) has never been opened, is RATHER BORING.
    Hangover, Germany
    I think you have a display with 2 lines of 16 characters.
    On the backside of the display you can find only one drop of black plastic.
    The Controller (under the plastic) can NOT manage these display in the desired way. The display ist broken into 4 parts of 8 characters.
    look at this:
    ;Display clear
    Disp_Clr:
    LCDOUT $FE,1isp_Zeile2=0:Return
    ;goto the second (right) part of a line
    Disp_Tab:
    LCDOUT $FE
    IF Disp_Zeile2 THEN
    LCDOUT $C8
    LCDOUT $88
    ;goto the second line
    Disp_LF:
    LCDOUT $FE,$C0isp_Zeile2=1
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 07:13
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:05
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
