what is the bit instruction to get to LCD line2
Results 1 to 9 of 9
    EDWARD's Avatar
    EDWARD Guest
    Default what is the bit instruction to get to LCD line2
    How do i get the cursor down to the 2nd line?
    i have a 2 line lcd that im using in 4 bit mode. i cant seem to diplay any data on the lower half of the screen (line 2).
    i have looked all over but can only find the home command to be the closest thing.( which takes the cursor to line 1 cell 1)
    i cant use any of the lcdout feature cause my pcb is wired weird. I need the actually byte command sent to the instruction registers on the LCD.
    have i over looked something? because if i just keep displaying on the top line it doesnt "Wrap" the text down to line 2.
    BTW, i got almost all of my project done, just wanted to say thanks for all the help so far.
    Angry
    The Manual !!!!
    with LCDOUT $FE,$C0 so i guess your routine must send only $C0 to the LCD... OR the same way when you do the LCD initialisation at start-up time.
    Dec 2003
    Wichita KS
    Hello Edward,
    If I am correct, were you not working on your own LCD routine??
    If so, Treat it exactly like the LCDout....
    Send a $FE, then a $C0 (if you have a routine) like the one I posted...
    If not, turn on your Command/Data pin to Command, and write a $CO.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    EDWARD's Avatar
    EDWARD Guest
    Default thanks
    i havent tried it yet but i think you are correct. yes dwayne i im doing "custom" lcd routines, great memory my man.
    thats why i cant use the lcdout function.
    what manual? i have the hd44780 commands sheet, i was having trouble interprting what the command actualy did, i also went to like 5 different webpages i found listed through out this forum to try and find a laymans description of what setting the dd reisters and stuff actually does.
    http://www.geocities.com/SiliconVall...d/commands.htm
    http://home.iae.nl/users/pouweha/lcd/lcd.shtml
    http://www.perfectlcd.com/FAQ_LCD_te...ter_module.htm
    so dont get so mad at people Ace.
    >> what manual?
    All the valid LCD I/O commands (certainly the cursor line-locating commands) are in the PICBasic manual that came with your PBP software (also available from the MeLabs website).
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 07:13
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:05
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
