New user frustration (16F688 + LCD)
Results 1 to 11 of 11
    Default Re: New user frustration (16F688 + LCD)
    Hey hey, it works!
    Henrik, I changed all of the ports over to PortC (0-5) as you suggested. When I powered-up, the display said "ello" and "orld", in the upper-left corner. It was obviously dropping the first character, but to me that was 99.999% success!
    Tasmod, I put your code in, and now the display says "Hello." and "World." in the lower-left corner. So, you were right.
    You guys helped me get over my first MAJOR hurdle, now I can work on the LCD text formatting and other smaller issues. I learned alot through this, mostly that each PIC device must be studied very closely and its ports set/configured properly. I know I have a long way to go, but its a great relief to be moving forward again.
    Thanks so much for your help!
    Bill
    That's great!
    Either you just need a little longer Pause at the beginning to allow the display to power up or, more likely, the clear screen command takes a little longer to execute than you are giving it.
    You can increase the timedelay for command with DEFINE LCD_COMMANDUS 2000, for example.
    Once you have a couple of projects under your belt you get a feeling of what might be the problem when something doesn't work. I'd say that having analog functions switched on pins you want to use as digital is by far the most common issue people stumble across around here, followed by read-modify-write issues which sometimes is caused by analog functions not being switched off in the first place.
    Keep it up and welcome to the forum!
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 18:53
  2. PICbasic and 40X4 lines LCD
    Last Post: - 28th January 2013, 22:42
  3. LCD using 4 data lines, Lab X1
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 20th January 2013, 23:10
  4. LCD Low Power
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2012, 00:05
  5. forum posting frustration
    By Heckler in forum Forum Requests
    Last Post: - 16th March 2012, 11:31
