Thank you Paul and Henrik, for trying to help.
Henrik, I tried the CMCON = 7 command, but it generated a syntax error and wouldnt compile. I searched the web for similar topics, and it was suggested to use CMCON0 = 0, and that compiled without any error. However, the LCD still doesnt work.
In my search, I found this thread http://www.picbasic.co.uk/forum/arch...hp/t-4896.html , which mentions a patch for PBP, which fixes 16F688 register issues. I wonder if thats what I need to do?
Here is my current program, which only produces a line of black boxes on the LCD. The LED does blink, as expected....
CMCON0 = 7 'Disable both comparators
ANSEL = 0 ' Set all analog pins to digital
' Set LCD Enable port
DEFINE LCD_EREG PORTC
' Set LCD Enable bit
DEFINE LCD_EBIT 0
LED VAR PORTC.1 ' Pin-9 on 16F688
Pause 500 ' Wait for LCD to startup
mainloop:
Lcdout $fe, 1 ' Clear LCD screen
Lcdout "Hello" ' Display Hello
high LED
Pause 500 ' Wait .5 second
Lcdout "World"
LOW led
Goto mainloop ' Do it forever
Thanks for any other further help or ideas.
Bill
