Hi guys:
Aratti; I already tried tmr1 interrupt on overflow, as you are suggesting, I explained that, on my post on July 21st, it’s just that seem to take too long to stop the motor and I get much more than I am barging for, sort of speech, also tried external interrupts on RB.0, and lastly polling from what I got much better results if you like to take a look to that post, I even included the code I used for each attempt.
Archangel; thank you for that, I already took a look to Darrel’s page and downloaded his .bas files and included, them on the PBP folder, (I feel relief now), but I’ll to try this first, since I got everything setup, and due to that I have fairly good results on polling, using the same encoder disc it measures twice de input because it is counting up on every negative and positive pulse, so just finished while ago a disc with 75 slot’s about half the other one, if still no good output then I try Darrel’s code, I’ll let you all know as soon as I get around it.
