Help whit tmr1 on pic16f877a
Results 1 to 16 of 16
    Apr 2012
    Unhappy Re: Help whit tmr1 on pic16f877a
    Thanks for answering Archangel.
    I don’t know the meaning of IMHO, but I appreciate your comment, now I am terrified to ask, do I have to do the hole code in assy?, I mean I been working on this project for over a year, you know, bumping my head around to get the hang of pbp, even blowing a couple pics and a few other components, I don’t main, there is no rush, just want to see it completed an working as I want to, I do not know anything about assembler, but yet I willing to learn if that is what it takes, on the meaning time I’ll take a look at Darrel’s interrupts.
    Default Re: Help whit tmr1 on pic16f877a
    IMHO = In My Humble Opinion, good luck. Funny I don't even use cell phone . . .
    No ooooooo
    Here is a timer1 demo I made tonight for 16F690
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOR_OFF & _FCMEN_OFF & _IESO_OFF
    INCLUDE "DT_INTS-14.bas"    ; Darrel Taylors instant interrupts
    ; * * * * * * * * * * * * * Setup Darrel's Instant Interrupts * * * * * * * *
    INT_LIST  macro   ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler    TMR1_INT,    _Flash,   ASM,  no
    @   INT_ENABLE   TMR1_INT     ; enable external (INT) interrupts
    ; * * * * * * * * * * * * * Provide system variables to save return address' * * * *
    ;wsave   VAR BYTE    $20     SYSTEM      ; location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ; alternate save location for W
    ; * * * * * * * * * * * * SETUP DEBUG Parameters * * * * * * * * * * * * *
    DEFINE DEBUG_MODE  0    ' Debug sending True serial data
    DEFINE DEBUG_REG_PORTA  ' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUG_BIT 0      ' Debug.bit = PortA.0
    DEFINE DEBUG_BAUD 19200  ' Default baud rate = 9600
    DEFINE DEBUGIN_REG PORTA' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUGIN_BIT 1    ' Debugin bit PortA.1
    DEFINE DEBUGIN_BAUD 19200' Default baud rate = 9600
    DEFINE DEBUGIN_MODE 0   ' Debugin receiving data true = 0 inverted = 1
    ; * * * * * * * * * * * * Setup Timer 1 registers  * * * * * * * * * * *
    TMR1IF var PIR1.0       ' Explain to PBP which bit is the T1IF bit
    INTCON     = %11010000   ; GIE,PEIE,T0IE,INTE set RABIE,T0IF,INTF,RABIF cleared
    PIR1       = %00000000
    PIE1       = %00000001   ;      -,ADIE  ,RCIE ,TXIE ,SSPIE  ,CCP1IE,TMR2IE,TMR1IE
    T1CON      = %01000101   ; T1GINV,TMR1GE,T1CKP,T1CKP,T1OSCEN,T1SYNC,TMR1CS,TMR1ON
    CM2CON1    = %00000000
    temp     var word
    overFlow var word
    overFlow      = 0
    temp.highbyte = 0
    temp.lowbyte  = 0
       if temp.lowbyte >= 255 then
            temp.highbyte = temp.highbyte +1
       if temp >= 65535 then
          overFlow = overFlow + 1 ;track number of temp roll overs
    debug " Temp Var High = ",#temp.highbyte," Temp Var Low = ",#Temp.Lowbyte," ",10
    debug "OverFlow = ",#overFlow," temp var ",#temp,10
    ; * * * * * * * * * * * * * End of Main Function * * * * * * * * * * * * *
    @ INT_DISABLE  TMR1_INT
    Flash:
            if TMR1IF  then       ; Flash is the ISR
                temp = temp + 1 ; add 1 to timer roll over count
    TMR1L = 0                   ; preload timer 0 with ? of 255 allows you to set counts until reset
    TMR1H = 0
    TMR1IF = 0                    ; Clear T1 Interrupt flag bit
    @  INT_RETURN
    All this does is overflow the timer and display the results in PICKit2 USART display. It has Darrel's Instant Interrupts installed so you can pretty much copy paste, then use your registers as required
    May 2008
    Italy
    Hi Don, here my suggestion. If your max encoder count is not bigger of 65535 then you can feed your encoder pulses directly to timer1 input (pin 15 of you 16f877). Timer1 has to be set as a counter using "T1CON = %00000111" and then you have two ways to control your motor.
    1) You poll the timer1 register TMR1H and TMR1L to see when the count reaches the desired value to stop the motor.
    Or
    2) you use DT interrupt (as already suggested) and you just load the count in Timer1 register (you have to load the complement : 65535-desired count) and wait for the overflow. In other words when the count is reached the value of the timer1 counter will be 65535 and adding one pulses it will overflow invocking the interrupt. In this routine (called ISR) you will stop your motor.
    If your needed count is greater then 2^16 it it still possibile to use timer1 as a counter but in this case interrupt is mandatory.
    Cheers
    Al.
    Apr 2012
    Red face Re: Help whit tmr1 on pic16f877a
    Hi guys:
    Aratti; I already tried tmr1 interrupt on overflow, as you are suggesting, I explained that, on my post on July 21st, it’s just that seem to take too long to stop the motor and I get much more than I am barging for, sort of speech, also tried external interrupts on RB.0, and lastly polling from what I got much better results if you like to take a look to that post, I even included the code I used for each attempt.
    Archangel; thank you for that, I already took a look to Darrel’s page and downloaded his .bas files and included, them on the PBP folder, (I feel relief now), but I’ll to try this first, since I got everything setup, and due to that I have fairly good results on polling, using the same encoder disc it measures twice de input because it is counting up on every negative and positive pulse, so just finished while ago a disc with 75 slot’s about half the other one, if still no good output then I try Darrel’s code, I’ll let you all know as soon as I get around it.
    May 2008
    Italy
    I suggested timer1 overflow with a true interrupt (Darrel Taylor interrupt) your code didn't use any interrupt.
    You can try to use this simple snippet which uses the timer1 as a counter, without interrupt and works pretty well.
    False           con 0
    True            con 1
    Z0               Var Byte
    Cnts            var word
    Tape_Len        Var Word
    Logic_1         var portXx  ' any available free input
    Motor = False
    Brake = False
    TMR1H = 0
    TMR1L = 0
    Main_Loop:
    If ????? goto  Load_Tape
    If ????? goto Set_Tape_L
    goto Main_loop
    Set_tape_L:
    Tape_Len = XXXXX ' encoder pulses derived from the tape lenght desired
    Start_Motor:
    Brake = False
    Motor = True
    Stop_Motor:
    Motor = false
    Brake = True
    Pause 200
    Brake = False
    T1CON.0 = False
    Load_Tape:
     Cnts = 0
    TMR1H = 0
    TMR1L = 0
    T1CON.0 = true
    Resume_Halt:
    Lcdout $FE, 1,   "  Press Yy to stop  "
    Lcdout $FE, $C0, "--------------------"
    Lcdout $FE, $94, "Now Loading Tape ..."
    Lcdout $FE, $D4, "Loaded: ",dec Cnts
    Gosub Start_Motor
    For Z0 = 0 To 100                               ' 100 millisecs delay
    pause 1
    if Logic_1 = True then Hw_Halt                  ' check if emergency stop is activated
    Next Z0
    Winding:                                                ' loading start here
    Cnts.highbyte = TMR1H
     Cnts.lowbyte = TMR1L
             If Cnts => Tape_Len then
             gosub Stop_Motor                           ' if count = lenght desired stop motor
             goto Main_Loop
             End If
       if Logic_1 = True then Hw_Halt                ' If emergency stop key pressed stop motor
    Lcdout $FE, $D4, "Loaded: ",dec Cnts            ' display updated count
    goto Winding
    Hw_Halt:
    gosub Stop_Motor
    Emergency_menu:
    1) if ????? then goto Resume_Halt
    2) if ????? then goto Main_Loop
    goto Hw_Halt
    Naturally you need to complete the code replacing the parts with ?????? and Xx with reference to your hardware setup.
    Cheers
    Al.
  1. Control de puertos PIC16F877A / Port Control PIC16F877A
    By martintorres in forum mel PIC BASIC Pro
    Last Post: - 4th October 2013, 04:49
  2. Tmr1
    By BobSpencerr in forum General
    Last Post: - 13th May 2008, 21:19
  3. Replies: 9
    Last Post: - 4th February 2008, 20:12
  4. problem whit pic18f452
    By ocastrillo in forum General
    Last Post: - 9th March 2007, 17:18
  5. TMR1 How it works?
    Last Post: - 12th January 2007, 15:24
