Help whit tmr1 on pic16f877a
Results 1 to 16 of 16
Threaded View
  1. #12
    Default Re: Help whit tmr1 on pic16f877a
    IMHO = In My Humble Opinion, good luck. Funny I don't even use cell phone . . .
    do I have to do the hole code in assy?
    No ooooooo
    Here is a timer1 demo I made tonight for 16F690
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOR_OFF & _FCMEN_OFF & _IESO_OFF
    INCLUDE "DT_INTS-14.bas"    ; Darrel Taylors instant interrupts
    ; * * * * * * * * * * * * * Setup Darrel's Instant Interrupts * * * * * * * *
    INT_LIST  macro   ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler    TMR1_INT,    _Flash,   ASM,  no
    @   INT_ENABLE   TMR1_INT     ; enable external (INT) interrupts
    ; * * * * * * * * * * * * * Provide system variables to save return address' * * * *
    ;wsave   VAR BYTE    $20     SYSTEM      ; location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ; alternate save location for W
    ; * * * * * * * * * * * * SETUP DEBUG Parameters * * * * * * * * * * * * *
    DEFINE DEBUG_MODE  0    ' Debug sending True serial data
    DEFINE DEBUG_REG_PORTA  ' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUG_BIT 0      ' Debug.bit = PortA.0
    DEFINE DEBUG_BAUD 19200  ' Default baud rate = 9600
    DEFINE DEBUGIN_REG PORTA' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUGIN_BIT 1    ' Debugin bit PortA.1
    DEFINE DEBUGIN_BAUD 19200' Default baud rate = 9600
    DEFINE DEBUGIN_MODE 0   ' Debugin receiving data true = 0 inverted = 1
    ; * * * * * * * * * * * * Setup Timer 1 registers  * * * * * * * * * * *
    TMR1IF var PIR1.0       ' Explain to PBP which bit is the T1IF bit
    INTCON     = %11010000   ; GIE,PEIE,T0IE,INTE set RABIE,T0IF,INTF,RABIF cleared
    PIR1       = %00000000
    PIE1       = %00000001   ;      -,ADIE  ,RCIE ,TXIE ,SSPIE  ,CCP1IE,TMR2IE,TMR1IE
    T1CON      = %01000101   ; T1GINV,TMR1GE,T1CKP,T1CKP,T1OSCEN,T1SYNC,TMR1CS,TMR1ON
    CM2CON1    = %00000000
    temp     var word
    overFlow var word
    overFlow      = 0
    temp.highbyte = 0
    temp.lowbyte  = 0
       if temp.lowbyte >= 255 then
            temp.highbyte = temp.highbyte +1
       if temp >= 65535 then
          overFlow = overFlow + 1 ;track number of temp roll overs
    debug " Temp Var High = ",#temp.highbyte," Temp Var Low = ",#Temp.Lowbyte," ",10
    debug "OverFlow = ",#overFlow," temp var ",#temp,10
    ; * * * * * * * * * * * * * End of Main Function * * * * * * * * * * * * *
    @ INT_DISABLE  TMR1_INT
    Flash:
            if TMR1IF  then       ; Flash is the ISR
                temp = temp + 1 ; add 1 to timer roll over count
    TMR1L = 0                   ; preload timer 0 with ? of 255 allows you to set counts until reset
    TMR1H = 0
    TMR1IF = 0                    ; Clear T1 Interrupt flag bit
    @  INT_RETURN
    All this does is overflow the timer and display the results in PICKit2 USART display. It has Darrel's Instant Interrupts installed so you can pretty much copy paste, then use your registers as required
  1. Control de puertos PIC16F877A / Port Control PIC16F877A
    By martintorres in forum mel PIC BASIC Pro
    Last Post: - 4th October 2013, 04:49
  2. Tmr1
    By BobSpencerr in forum General
    Last Post: - 13th May 2008, 21:19
  3. Replies: 9
    Last Post: - 4th February 2008, 20:12
  4. problem whit pic18f452
    By ocastrillo in forum General
    Last Post: - 9th March 2007, 17:18
  5. TMR1 How it works?
    Last Post: - 12th January 2007, 15:24
