Help whit tmr1 on pic16f877a
Results 1 to 16 of 16
Threaded View
  1. #4
    Apr 2012
    Default Re: Help whit tmr1 on pic16f877a
    Hi there:
    I apologize for taken so long to reply but in between attending a job and a family my time left to do other things is from very slim to none.
    Anyways after messing around with the code I came out with something that works at least on the isis proteus simulator, one thing that I noticed is that when I press the encoder button the tmr1 value increment in more than one unit, but I think that’s because I didn’t put any debouncing time on the code I’ll check that out.
    I going to leave de code and a snapshoot of the circuit for you to look at it and if you will comment about it, but please don´t be to rough on me, since this is my first code for something useful other than blinking leds.
    About the code (this is just part of it) is to be used with an incremental encoder, I mean it only send pulses and not difference which way is turning, it is only to measure distance and to cause an interrupt whenever the set distance has been reached, ahhh and one other thing, does any body can tell me how to increase the count, because the tmr1 only counts up to little more than 65 meters before it overflows, providing than each pulse equals one millimeter
    'Name : TAPE MEASURING
    'Author : [Don Luis]
    'Notice : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS]
    'All Rights Reserved
    'Date : 02/02/2013
    'Version : 1.0
    'Notes : PROGRAM CODE TO TEST THE TMR1 OPERATION
    ' FUSES DEFINE
    DEFINE HS_OSC,WDT_OFF,PWRT_ON, BOD_OFF,LVP_OFF,CPD_OFF,WRT_HALF,DEBUG_OFF,PROTECT _OFF
    ' LCD INITIALIZING
    DEFINE LCD_DREG PORTB ' set portb for lcd
    DEFINE LCD_DBIT 4 ' set data bit from 4 to seven
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2 ' set bit 1 as RS bit
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3 ' set bit 2 as enable bit
    DEFINE LCD_BITS 4 ' define number of data bits
    DEFINE LCD_LINES 2 ' define number of lines
    DEFINE LCD_COMMANDUS 2000 ' set time for lcd to start
    DEFINE LCD_DATAUS 50 ' set time for lcd data transfer
    pause 2000
    'INITIALIZING SFR'S
    adcon1= %10001110
    PIE1= %00000001 ' Periferal interrupt enable tmr1
    INTCON= %11000000 ' TMR1 interrupt control off
    on interrupt goto motstop ' Interrupt handdler
    'SETTING TRIS
    trisa= %11110011
    trisb= %00000001
    trisc= %11111111
    trisd= %11110000
    trise= %000
    ' PORT DEFINING
    encoder var portc.0 ' variable for encoder signal input
    motor var porta.3 ' variable for motor control
    brake var porta.2 ' variable for brake control
    ' SETTING VARIABLES
    t1val var word ' set variable to store tmr1 value
    tempo var byte ' set variable for timing pause
    medida var word ' set variable to store required travel distance
    tctval var word ' set variable used to display the actual tmr1 value
    'INITIALIZING VARIABLES
    tempo= 50
    t1val=0
    medida= 10
    tctval= 0
    'INITIALIZING PORTS
    low brake
    low motor
    lcdout $FE,$01 ' clear lcd display line 1
    pause 20 ' small pause to give time to lcd
    lcdout " SYSTEM READDY" ' display introduction message
    pause 5000 ' during 5 seconds
    t1val=65535-medida ' load tmr1 whith FFFF- the value of medida
    TMR1H = t1val.highbyte
    TMR1L = t1val.lowbyte
    T1CON=%00000111 ' enable tmr1
    high motor ' turn motor on
    rutpal:
    tctval.highbyte= TMR1H
    tctval.lowbyte= TMR1L ' load tctval variable with actual timer value
    if TMR1H=0 & TMR1L=0 then ' this command is used to prevent the program from
    goto main ' going into an endless loop after a return from
    endif ' an interrupt routine
    lcdout $FE,$01 ' clear display line 1
    lcdout "TIMER VALUE" ' display message on line 1
    pause 20 ' pause to give the lcd some time to execute
    lcdout $FE,$C0 ' clear display line 2
    lcdout dec tctval ' display decimal value of tctval on line 2
    pause 100 ' small pause
    goto rutpal ' loop untill a interrupt ocurrs
    disable ' disable all interrupts
    motstop: 'interrupt handler
    low motor ' stop the motor
    high brake ' turn brake on
    pause 2000 ' pause just we can see de led on for a moment
    low brake ' turn brake off
    TMR1H=0 ' clear tmr1
    TMR1L=0
    T1CON=%00000110 ' disable tmr1
    lcdout " CYCLE" ' display message on line 1
    pause 20 ' small pause to give time to the lcd to execute
    lcdout $FE,$C0 ' clear line two of lcd
    lcdout " CONCLUDED" ' display message on line two of lcd
    PIR1.0=0 ' clear flag
    pause 2000 ' two second pause
    resume ' end interrupt routine
    enable ' enable interrupts
  1. Control de puertos PIC16F877A / Port Control PIC16F877A
    By martintorres in forum mel PIC BASIC Pro
    Last Post: - 4th October 2013, 04:49
  2. Tmr1
    By BobSpencerr in forum General
    Last Post: - 13th May 2008, 21:19
  3. Replies: 9
    Last Post: - 4th February 2008, 20:12
  4. problem whit pic18f452
    By ocastrillo in forum General
    Last Post: - 9th March 2007, 17:18
  5. TMR1 How it works?
    Last Post: - 12th January 2007, 15:24
