HSERIN with a WAIT
Results 1 to 3 of 3
    Jun 2006
    Default HSERIN with a WAIT
    Trying to get 3 different HSERIN to work. The 3 different ones come in at different times & will never effect the other.If I put the wait statements in there nothing happens, take the first one out & I pull in all 9 DEC4. Am I using this wrong?Using a PIC16F690
    define OSC 4
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    include "ReEnterPBP.bas"
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
    '-----------------------Enable EUSART------------------------------------
    DEFINE HSER_SPBRG 51  ' 4800 Baud @ 4MHz, 0.17%
    SPBRGH = 0
    BAUDCTL.3 = 1         ' Enable 16 bit baudrate generator
    '-----------------------REGISTERS----------------------------------------
    TRISA=%001000                                                   ' RA0,RA3,RA4,RA5 inputs
    ANSEL=%00000000                                                 ' All digital
    TRISC=%00000000                                                 ' RC5 input
    CMCON0=%111                                                     ' Shut off comparators
    OPTION_REG.7=0
    WPUA=%001000                                                    ' Weak Pull Ups Enabled
    rottime var word[10]
    rot1time var rottime[0]
    rot2time var rottime[1]
    rot3time var rottime[2]
    rot4time var rottime[3]
    rot5time var rottime[4]
    rot6time var rottime[5]
    rot7time var rottime[6]
    rot8time var rottime[7]
    rot9time var rottime[8]
    rot10time var rottime[9]
    runtim var word [2]
    runtime var runtim[0]
    runbacktime var runtim[1]
    time var word
    RE var byte
    i var word
    DE_RE var PORTC.3
    'Interrupt---------------------------------------------------------------------
            INT_Handler    RX_INT,  _Receive,   PBP,  yes
        INT_ENABLE   RX_INT     ; enable external (INT) interrupts
     high PORTC.0
     low PORTC.0
    Receive:
    for i=0 to 9
       hserin 100,Receive2,[WAIT("&"),dec4 rottime[I]]
       next
    for i = 0 to 9
       hserout [dec4 rottime[I],13,10]
       next
       hserout [dec4 rot3time]
    Receive2:
      for i = 0 to 1
      hserin 100,Receive3,[wait(":"),dec4 runtim[i]]
       next
      for i = 0 to 1
      hserout [dec4 runtim[i]]
       next
    Receive3:
      hserin 100,moveon,[wait("*"),dec4 time]
    Moveon:
       @ INT_RETURN
    Default Re: HSERIN with a WAIT
    for i=0 to 9
    next
    Does each value have "&" as the character before the rottime,? if not then it will not work as you have told the program to wait for "&" prior to every rottime value.
    Jun 2006
    I get it now will try something different, thanks.
  1. wait for a string
    By sahin5002 in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 23:27
  2. HSERIN WAIT parameter
    By tishri in forum mel PIC BASIC
    Last Post: - 9th December 2008, 10:23
  3. Serin2 multi wait?
    By cburtis in forum mel PIC BASIC Pro
    Last Post: - 24th November 2007, 19:08
  4. SerIn & wait
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 24th May 2006, 14:56
  5. Pic16f84 and wait byte
    By irmus in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 23:49
Members who have read this thread : 5
