Motion profile generator.
Results 1 to 40 of 56
    Default Re: Motion profile generator.
    Hi guys,
    First of all, for clarity:
    The PID-loop is already in place. It servos the motor to the position given to it and does whatever it can to bring the motor to the commanded based P,I,D and feedforward parameters. If the error between the target position and actual position gets above a setable limit the loop faults and aborts. This is one of the reasons for needing the profile generator - I can't just ask the PID-loop to move the motor 10000 QCs (quadrature counts or steps or pulses or units or whatever we want to call it) because if I do an error of an equal amount (10000) will instantly develop and the loop will fault. Even if such large errors was allowed the resulting move would be less then optimal.
    The profile generators job, being discussed here, is to generate input TO the PID-loop which the motor and load is actually capable of following.
    The input to the profile generator can then be "stepped" 10000 QCs. It then will generate a velocity profile with the parameters given to it. Each "tick" the profile generator will give the PID-loop a new position for it to move the motor to during the next time interval. The PID-loop is executed between 500 and 2500 times per second and so will the profile generator. At least that's the idea.
    Darrel,
    Although I'm having some difficulties figuring out what the worst case scenario could be with the "green line approach" I don't think doing it that way should be any problem in real life. It's better to "stretch" the deceleration phase than to violate A_Max although I would prefer it symetrical but I get what you're saying - I think.
    Thanks!
    Darrel,
    Missed your last post while composing mine.
    You mean like a initial "step" (or steps) at a velocity less than A_Max, just to "break the edge" on the trapetzoidal/triangular profile? (If not, could you clarify?)
    That could help, ideally it should be at all four "corners" of the profile but having it at the start and end of the move is certainly better than nothing.
    Thanks again Darrel!
    Ok Henrik, here's what I came up with.
    To start a movement, set the three variables and call the ProfileStart subroutine.
    MaxAcceleration = 10     ; starting values
    MaxVelocity     = 100
    TargetPosition  = 2000
    GOSUB ProfileStart
    Then for each period, call the ProfileStep subroutine, and the variables ... ThisAccel, Velocity and Position will be updated.
    When the TargetPosition has been reached, the ProfileComplete flag will be set.
    For the above values, the output of the test program looks like this ...
    Like your original example, the first column is Acceleration change, second column Velocity, third column Position.
    1 = Edit MaxAcceleration (10)
    2 = Edit MaxVelocity     (100)
    3 = Edit TargetPosition  (2000)
    Enter = GO
       0       0       0
      10      10      10
      10      20      30
      10      30      60
      10      40     100
      10      50     150
      10      60     210
      10      70     280
      10      80     360
      10      90     450
      10     100     550
       0     100     650
       0     100     750
       0     100     850
       0     100     950
       0     100    1050
       0     100    1150
       0     100    1250
       0     100    1350
       0     100    1450
       0     100    1550
     -10      90    1640
     -10      80    1720
     -10      70    1790
     -10      60    1850
     -10      50    1900
     -10      40    1940
     -10      30    1970
     -10      20    1990
     -10      10    2000
     -10       0    2000
    Enter = GO
    I quickly tried the "Ease From" and "Ease To", but it messed up the final position so i pulled it back out.
    I'll have to think about it some more.
    The MaxAcceleration variable will get changed on small moves.
    So you should keep a separate variable and copy it to MaxAcceleration before starting a profile.
    Hopefully, this is somewhere close to what you were looking for.
    Try the test program, and as many combinations of the settings as you can first.
    I'd hate to ruin your CNC.
    If you can follow the code in the include file, and it makes sense ...
    You should see a psychiatrist as soon as possible.
    Apr 2011
    Kent, UK
    Henrik, I now understand what you are trying to do.
    We use our motor control for velocity regulation because we need smooth moves in our remote cameras. When we need to go to a QC position, we increment/decrement the velocity demand to achieve the target. Running it in a positional regulation tends to be quite "notchy" in our application, but I will try it and let you know how it goes.
    Tim.
    Darrel,
    Thanks a lot!
    Don't worry about ruining anything, this is for a stand alone application not related to my CNC machines. (For that you need multiple axis interpolating, all with different accelerations and velocity constraints - up for another challenge?).
    I'll take a closer look at it and run it thru its paces over the next few days. Really, thank you!
    Tim,
    Exactly, the PID-loop servos the motor to a position command. Giving it a new target position without any sort of profile doesn't work very well.
    To run at a certain velocity I make the motor "chase" an ever changing target position.
    Did you develop the code for the motion controllers you mention in PBP? Any links or information, I'd love to see them.
    Apr 2011
    Kent, UK
    Henrik,
    We work entirely in PBP. For the top end motor control and move profiling we currently use the Maxon EPOS2 controller, but we have better control at the very slow speeds than Maxon. We are moving to do all our own control including the gyro products.
    PM message sent.
    Sure, but it will take several months, many thousands of dollars, and a trip to Sweden.
    Let me know when you want to start.
    Hi Darrel,
    I've played around with the profile generator code and it's very cool. Unfortunately I won't pretend to understand half of it.
    There are a couple of issues, one of which I think is a bug.
    If you can, do a move with A=7, V=23, T=12345 - what do you get? When I do that it accelerates properly, runs at a velocity of 23 for a while then decides to decelerate to a velocity of 5 and finishes the move at that velocity. If I change to A=7, V=25, T=12345 it's fine but it does do similar things with other settings as well. So, I think something weird is going on there.
    The other issue is the WORD size limit on the lenght of move. I've managed to change it to LONGS (changed Position, TargetPosition, RampTotal and Value) and it seems to work that way but it is SO (I mean really) much slower to execute. What seems to be taking the longest time is the step right at the "corners" of the profile, I've seen times above 2500 cycles. I'm not sure there's anything that can be done to make it better but wanted to run it by you in case you may have some ideas.
    The last thing is one which I knew would come up from the start but I honestly couldn't imagine the code for this having to be THIS complicated and thought I'd be able to handle it outside of the actual profile generator but now I may need your input on what effects it will have on the profile generator code. The issue is resolution, or rather lack of resolution.
    Imagine a 3000rpm motor with a 500 line encoder giving 2000 counts per revolution. The servo-loop needs to run at ~1000Hz which means that lowest speed I can command is 1 count per interrupt (1000 counts per second) or 30rpm - not that great. And, even at the lowest possible acceleration of 1 count/tick/tick it'll still go from 0 to 3000rpm in 100ms.
    One possible solution might be to run the profile generator maby one in every ten servo-loop ticks. That would make it better but still pretty crude. Slower than that and it would be noticable I think.
    My original idea, which I've used before and thought I could use here as well is to use something like this:
    Scratchpad = Scratchpad + VelocityCmd.LowByte  'Accumulate scratchpad...
    If ABS (ScratchPad) > 127 then              ' If it's time to move 1 count...
       Scratchpad = Scratchpad - 256           ' reset the acumulator and...
       IF Direction = FWD THEN
           Setpoint = Setpoint + 1
          SetPoint = SetPoint – 1
       SetPoint = Setpoint + VelocityCmd.Highbyte
    Else
       SetPoint = Setpoint – VelocityCmd.HighByte
    Endif
    This allows me to set the velocity in steps of 1/256 counts per tick which is good enough and the idea was to use something similar for the acceleration. But, as I said, the profile generator code turned out to be much more complicated than I imagined and now I'm not sure I can do it without messing up the generator completely. I'm thinking I can make the velocity and acceleration variables WORD-sized and then handle the rest outside of the profile generator. What do you think, do you see any major issues with that?
    Sorry for the lengthy post and thanks again for all your help!
  1. Motion Capturing
    By koossa in forum Off Topic
    Last Post: - 30th June 2009, 12:05
  2. Suggest a motion sensor Please
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 14:22
  3. Wireless Motion Sensors.
    Last Post: - 17th October 2006, 22:57
  4. Need low Profile LCDs
    By Foxx373 in forum General
    Last Post: - 26th October 2005, 18:33
  5. Motion Tracking
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 5th November 2004, 01:58
