Thanks Darrel!
Actually, I don't think you should need to worry about the direction. Perhaps I misunderstood your earlier question and overcomplicated my explaination after all.
How about this:
* The "global position variable" is the expected motor position at any given time. The PID loop servos the motor to this position.
* The "relative position variable" is the output of the profile generator, exactly as you shown earlier, always starting a new move at 0.
* When a new move is commanded it is easy to calculate if the target position is positive or negative relative to the current "global position".
* A profile, starting at 0 and ending at ABS(Target Position - Global Position) is then generated.
* Depending on the direction or "polarity" the output of the profile generator is added or subtracted from the Global Position variable one "tick" at a time.
* The PID loop makes the motor follow the Global Position variable very smoothly and everyone's happy, especially me :-)
Does that make sense?
EDIT: Put another way... Acceleration is added to Velocity. Velocity is added to RelativePosition. RelativePosition is added to OR subtracted from GlobalPosition.
