Config fuse i n PBP3.0 - PIC16F828A
Results 1 to 5 of 5
    Jan 2013
    Default Config fuse i n PBP3.0 - PIC16F828A
    Hello Dear,
    I built a circuit and ran the LED on off code. I am using U2 programmer. I got an error 'ilegal opcode' when I defined the config fuses in the code. The code works fine without config fuse inserts but then I have to pick them in the programmer every time I download the code into the chip. Is there a way around?
    Thank you,
    IapIllc
    Oops! I typed 828A instead of 628A in the subject line and I can't change it now.
    Default Re: Config fuse i n PBP3.0 - PIC16F828A
    If you have PBP3 you should enclose your config directive in a #CONFIG / #ENDCONFIG block. When such a block is found in the PBP source file it will replace the default config in the device specific include file without the need to edit that file. Example:
          __config _XT_OSC & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    Note the double underscore in __config and make sure to indent it.
    Jan 2013
    Thank you Henrik,
    It works.
    Mar 2013
    Hi , I'm new here, upgrading from stamp based projects as I've exceeded their limits.
    Steep learning curve right now
    Also having reg. CONFIG1/ #config issues, I think I have seen the answers here.
    But:
    When I see the word "fuses" I get nervous
    Are these a pgm once and forever sort of thing? Or are these some kind of EEPROM that can be changed?
    What I'm doing is developing a MIDI based product [serial 31.25 kbd.] but the internal 8mhz oscillator doesn't seem to get me that baud rate.
    So I'm trying to use a 16meg external xtal instead Using PIC16F887
    No need to worry, as long as you don't use OTP-parts the "fuses" are reprogrammable - just as the program flash.
    Even if you set read and write protection you can always ERASE the PIC to get back to square one.
  1. 18F2620 pbp3 example config please
    Last Post: - 17th December 2014, 01:49
  2. 18F1220 fuse help
    By mr.sneezy in forum General
    Last Post: - 24th May 2010, 14:54
  3. Help with config fuse?
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 27th December 2009, 21:14
  4. fuse options in pbp
    By comwarrior in forum General
    Last Post: - 2nd August 2009, 23:07
  5. Fuse Error
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 29th October 2005, 15:42
