16F886 (illegal opcode CONFIG1)
Results 1 to 13 of 13
Threaded View
  1. #12
    May 2015
    Default Re: 16F876 (illegal opcode pic16f876)
    HELLO, I HAVE THE SAME PROBLEM YOU HAD SOLVED. PLEASE HELP ME TO COMPILE THIS CODE.
    @ DEVICE pic16F876
    @ DEVICE pic16F876, WDT_OFF
    @ DEVICE pic16F876, PWRT_On
    @ DEVICE pic16F876, PROTECT_OFF
    TRISA=%11111111
    TRISB=%00000000
    TRISC=%00000000
    PORTA=0
    PORTB=0
    PORTC=0
    DEFINE LCD_DREG      PORTB
    DEFINE LCD_DBIT      4
    DEFINE LCD_RSREG  PORTB
    DEFINE LCD_RSBIT  2
    DEFINE LCD_EREG      PORTB
    DEFINE LCD_EBIT   3
    DEFINE LCD_BITS      4
    DEFINE LCD_LINES  2
    DEFINE CCP1_REG   PORTC
    DEFINE CCP1_BIT   2
    ON INTERRUPT GoTo KESME
    ADCON1 = 7
    OPTION_REG=%10000010
    INTCON=%10100001
    TMR0=0
    T2CON = %00000110
    PR2=124
    SYMBOL YUKARI=PORTA.0
    SYMBOL  ASAGI=PORTA.1
    SYMBOL ARTTIR=PORTA.2
    SYMBOL  AZALT=PORTA.3
    SYMBOL    JOG=PORTA.4
    SYMBOL    DUR=PORTA.5
    ROLE  VAR PORTC.3
    LED1  VAR PORTC.1
    LED2  VAR PORTC.0
    MODS     VAR BIT
    YON      VAR BIT
    U        VAR BYTE
    W        VAR BYTE
    ADR      VAR BYTE
    SAYIH    VAR BYTE
    SAYIL    VAR BYTE
    SON      VAR BYTE
    SYC      VAR BYTE
    SNY      VAR BYTE
    SAYAC    VAR BYTE
    DUTY     VAR BYTE
    I        VAR WORD
    PERYOT   VAR WORD
    HAM_DUTY VAR WORD
    FREKANS  VAR WORD
    PAUSE 200
    LCDOUT $FE,1
    GIRIS:
    LCDOUT $FE,$83,"INVERTER"
    LCDOUT $FE,$C4,"WITH PWM"
    PAUSE 1500
    LCDOUT $FE,1
    DUTY=0:LED1=0:LED2=1
    GOSUB FREKANS_HESAP
    GOSUB EKRAN
    GOSUB DUTY_YAZ
    GOSUB PWM_ON
    BASLA:
    IF DUTY>0 THEN
    IF JOG=0 AND YON=0 THEN
      YON=1
      SON=DUTY
      GOTO SAG
    IF JOG=0 AND YON=1 THEN
    YON=0
    SON=DUTY
    GOTO SOL
    IF DUR=0 and duty>0 THEN
    GOTO DURDUR
    GOSUB FREKANS_HESAP
    GOSUB DUTY_KONTROL
    GOSUB FREKANS_KONTROL
    GOTO BASLA
    FREKANS_KONTROL:
    IF ARTTIR=0 THEN
    WHILE ARTTIR=0:WEND
    PR2=PR2-1
    gosub DUTY_YAZ
    IF PR2<5 THEN PR2=5
    IF AZALT=0 THEN
    WHILE AZALT=0:WEND
    PR2=PR2+1
    gosub DUTY_YAZ
    IF PR2>124 THEN PR2=124
    GOSUB EKRAN
    DUTY_KONTROL:
    IF YUKARI=0 THEN
    sayac=0
    DUTY=DUTY+1
    IF DUTY=101 THEN DUTY=100
    gosub DUTY_YAZ:GOSUB EKRAN
     WHILE YUKARI=0
     W=1
     IF SAYAC=>50 THEN
       W=0:SAYAC=50
       DUTY=DUTY+1:GOSUB DELAY
     GOSUB DUTY_YAZ
     GOSUB EKRAN
     WEND
     W=0:SAYAC=0
     W=0:SAYAC=0
    IF ASAGI=0 THEN
    sayac=0
    DUTY=DUTY-1
    IF DUTY=255 THEN DUTY=0
    GOSUB DUTY_YAZ
    GOSUB EKRAN
     WHILE ASAGI=0
     W=1
     IF SAYAC=>30 THEN
       W=0:SAYAC=30
       DUTY=DUTY-1:GOSUB DELAY
     GOSUB DUTY_YAZ
     GOSUB EKRAN
     WEND
     W=0
     W=0:SAYAC=0
    SAG:
    IF DUTY>100 THEN
    ROLE=1:LED1=1:LED2=0
    GOTO DUTY_ARTTIR
    GOSUB DUTY_YAZ:GOSUB EKRAN
    GOTO SAG
    DUTY_ARTTIR:
    IF DUTY=SON THEN
    GOTO BASLA
    GOTO DUTY_ARTTIR
    DURDUR:
    IF DUTY=0 THEN
    GOTO BASLA
    GOTO DURDUR
    SOL:
    IF DUTY>100 THEN
    ROLE=0:LED1=0:LED2=1
    GOTO DUTY_ARTTIR
    GOTO SOL
    DELAY: 'gecıkme
      FOR I=0 TO 255:NEXT
    DELAY1:
      FOR I=0 TO 150:NEXT
    FREKANS_HESAP:
    FREKANS=62500/(PR2+1)
    DUTY_YAZ:
    HAM_DUTY=(PR2+1)*DUTY/25
    CCP1CON.4=ham_DUTY.0
    CCP1CON.5=HAM_DUTY.1
    CCPR1L=HAM_DUTY>>2
    PWM_ON:
    CCP1CON.2=1
    CCP1CON.3=1
    PWM_OFF:
    CCP1CON.2=0
    CCP1CON.3=0
    EKRAN:
    LCDOUT $FE,$80,"Duty %",#DUTY
    IF DUTY<100 THEN
    GOSUB HANE_AL1
    LCDOUT $FE,ADR,$20
    lcdout $fe,$C0,"FREKANS=",#FREKANS
    GOSUB HANE_AL2
    HANE_AL1:
    IF DUTY<100 OR DUTY>9 THEN ADR=$88
    IF DUTY<10 THEN ADR=$87
    HANE_AL2:
    IF FREKANS>10000 THEN LCDOUT $FE,$CD,"Hz"
    IF FREKANS<10000 AND FREKANS>999 THEN LCDOUT $FE,$CC,"Hz "
    IF FREKANS<1000 THEN LCDOUT $FE,$CB,"Hz "
    DISABLE
    KESME:
    IF W=1 THEN
          SAYAC=SAYAC+1
          IF SAYAC=101 THEN SAYAC=0
    INTCON.2=0
    RESUME
    ENABLE
  1. Illegal upcode
    Last Post: - 10th November 2011, 23:31
  2. Extra I2CWRITE opcode at beginning of *.hex file
    By tturpin in forum mel PIC BASIC Pro
    Last Post: - 24th May 2011, 03:13
  3. NTVDM CPU has encountered illegal instruction
    By Sanddune in forum mel PIC BASIC Pro
    Last Post: - 19th June 2009, 04:01
  4. 16f886
    By Larry in forum mel PIC BASIC Pro
    Last Post: - 4th November 2008, 16:57
  5. 16f886
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 27th May 2008, 05:06
