TOGGLE will not go LOW
Results 1 to 18 of 18
    Default Re: TOGGLE will not go LOW
    looks like I went off on the wrong path again, but I'd say archangel is 100% correct . if only people would post their complete code (or complete compilable example demonstrating the problem) speculation would be unnecessary,
    dream on
    Feb 2011
    According to data sheet 18F4620 making one port analog makes all smaller number ports analog which interferes with TOGGLE. IF AN5 is analog then AN0 thru AN4 are also analog, like a pyramid. TOGGLE is not needed. Adding a bit to an output pin toggles that pin, analog or not.
  1. Super low cost USB solution
    By Jumper in forum General
    Last Post: - 18th January 2013, 11:21
  2. high/low of 14 numbers
    Last Post: - 16th December 2012, 09:43
  3. LCD Low Power
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2012, 00:05
  4. PCB low volume production
    By sales5 in forum Adverts
    Last Post: - 29th November 2012, 03:43
  5. Replies: 3
    Last Post: - 25th November 2012, 20:26
