Pic16f88
Results 1 to 4 of 4
Thread: Pic16f88
    Maurice's Avatar
    Maurice Guest
    Default Pic16f88
    Can somebody tell me if the internal 8MHz oscillator is accurate enough to drive proper RS232 timings out of the 16F88? Is it also possible to use it when I'm using the normal serout2/serin2 from a general I/O pin of that chip.
    thanks, Maurice
    depending of your baudrate, temperature change, and few others... it can be accurate enough to work.
    Why using SERIN/SEROUT on a F88 when you can use the internal USART capability with HSERIN/HSEROUT instead???
    Maurice's Avatar
    Maurice Guest
    Default 16F88 internal oscillator and RS232
    Hi Mr_e,
    thanks again for the response on the RS232 question. It sounds to me that it may be a bit dodgy to use the internal oscillator and the old RS232 methods. Guess I'll have to bite the bullet and learn about the real serial ports on the '88. Its just that I had some old code I can pop into the '88 and no further thought needed. Can the official hardware method be any better for accuracy since it must use the same internal oscillator? (?)
    thanks again
    Spencer
    the internal one is still an RC oscillator that shift with the ambient temperature. It can work fine or no. For solid and safe serial communication using external crystal (not ceramic resonator) is the way to go. At slow baudrate like 2400,4800, INTRC will be good enough IMO.
    The use of internal USART, depending of the register setting, can provide much accuracy and faster baudrate on slower crystal frequency... see usart SPBRG setting. Another main advantage, to name only one, is to use less of that precious code space.
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
  2. pic16f88 & voltage
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 17th February 2009, 10:14
  3. Ghange code from PIC16F877A to PIC16F88
    Last Post: - 12th March 2008, 17:09
  4. Replies: 8
    Last Post: - 7th December 2006, 16:42
  5. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 18th September 2006, 00:31
