Low ESR Capacitors?
Results 1 to 8 of 8
    Lightbulb Low ESR Capacitors?
    Good day
    I have asked for low ESR Electrolytic Capacitors, and they gave me the following 3 types :
    http://www.hitano.com.tw/PDF/EXR.pdf
    http://www.hitano.com.tw/PDF/E5R.pdf
    http://www.hitano.com.tw/PDF/EHR.pdf
    How do I know if they are low esr?
    Jan 2013
    Default Re: Low ESR Capacitors?
    first of all, you must make an ESRmeter circuit and then measure them. its the best action, trust me.
    the cheapest way to measure ESR is with a digital storage oscilloscope and a simple R network.
    If you have this tool, tell me to look for the setup and post it.
    Capacitors are very tricky in high (>40C) temperatures and if you have around heatsinks or other elemets that they are getting hot, please consider moving them away.
    Maxim I recall had a nice tutorial oin this subject but cannot find it now. When..., I will...
    Dec 2010
    If ESR or ESL is critical, then perhaps electrolytics are not the way to go. What value do you need?
    Here is the promissed link for the capacitors that can be the bad guy in your circuit.
    http://pdfserv.maximintegrated.com/en/an/TUT5527.pdf
    Dec 2010
    Quote Originally Posted by koossa View Post
    Good day
    I think you will have to call the manufacturer and ask - the data sheets provided don't specify it. You will need to know your frequency of operation, voltages, and temperature since these impact it as well. Someone mentioned getting a sample and measuring it which is a good place to start, but you will need a spec if you want to use it in a commercial design. I'm not sure why the paper on ceramics was posted, but Electrolytics and not known for great ESR / ESL, so you may wish to look at a different technology like ceramic, metal film, or even tantulum depending on your application, in which case the paper is a good reference.
    We can probably help more with better information about what you are doing and what your circuit looks like. As usual, the answer varies widely depending on the application.
    Apr 2007
    Pennsylvania, USA
    I don't think he needs help anymore since the thread dates back to 2005
    Shawn
    Dec 2010
    LOL - I missed that Shawn - good spotting.
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  2. Pic16f84 and RC5 kode
    By terminator in forum Bluetooth
    Last Post: - 18th June 2007, 21:40
  3. Microcontroller with 2 way paging application problem
  4. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 17:19
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 03:14
