DT_INTS-14 ver 1.10 and PBP V2.60C What am I doing wrong?
Results 1 to 4 of 4
    Dec 2012
    Georgia, USA
    Default DT_INTS-14 ver 1.10 and PBP V2.60C What am I doing wrong?
    I am very new to PBP, have done a good bit of research on Darrel Taylor's
    DT_INTS-14 ver 1.10. I really like what I have read on this Forum about it's
    abilities to do interrupts on HESRIN. I downloaded Darrel's package and started
    by trying his first sample (Hello World Toggling an LED) and found out Just how
    much I don't know about PBP. When I compile I get assembler errors.
    Is there link options that must be set for INCLUDE Files?
    Thanks In Advance for any direction.
    Attachment 0Name:  LINKERR.PNG
    Default Re: DT_INTS-14 ver 1.10 and PBP V2.60C What am I doing wrong?
    Hi and welcome to the forum!
    I think it actually tells you what to do in the error message, ie try adding the followin to your code, before including the DT-INTS file:
    wsave VAR BYTE $70 SYSTEM
    wsave1 VAR BYTE $A0 SYSTEM
    wsave2 VAR BYTE $120 SYSTEM
    wsave3 VAR BYTE $1A0 SYSTEM
    Try to remember to include for which PIC you're compiling when posting, it makes helping easier.
    Dec 2012
    Georgia, USA
    Thank you Henrik !!
    You are totally right that was the trouble.
    Sorry I missed that, Slow learner I guess.
    The PIC I'm Compiling for is a 16F877.
    Thank you again for your help!
    Larryd
    This is very interesting as I have had the same exact problem (AFAIK), same pic, PBP 2.60 and added the extra lines of code as suggested and still got the same error. I opened up DT_INTS-14.bas and found the following
    wsave VAR BYTE $20 SYSTEM ' location for W if in bank0
    'wsave VAR BYTE $70 SYSTEM ' alternate save location for W
    ' Comment them out to fix the problem ----
    wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
    wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2
    wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3
    I am using MPLABX v1.95 under Windows 8.1 I have used Darrel Taylor's code in the past using this chip (IIRC) but using MPLAB 8.x under Windows XP and never had a problem (except for typo's!) I can compile other code with this setup that doesn't include the Instant Interrupts and this is the first time I have tried to use Darrel's code on my new setup. I'm wondering if in fact I may not have something set up in MPLAB-X correctly? Any suggestions appreciated. Chris
  1. Math problem with PBP 2.6 and 18F4550, large numbers
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2013, 04:41
  2. pbp and linux
    By Chirpy in forum mel PIC BASIC Pro
    Last Post: - 17th December 2012, 22:37
  3. PBP and DT_INTs problems
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 14th December 2012, 11:45
  4. Replies: 1
    Last Post: - 30th October 2012, 09:28
  5. Replies: 5
    Last Post: - 16th October 2012, 20:31
