Weird problem with 12F629
Results 1 to 5 of 5
    martarse's Avatar
    martarse Guest
    Unhappy Weird problem with 12F629
    Hello,
    Here is the code I want to make it working :
    define OSC 3
    trisio = %001
    firstline:
    if (GPIO.0 = 0) then
    high GPIO.2
    low GPIO.2
    goto firstline
    It's a very simple program that works with 16f84a (if I change GPIO for PORTx) but do not works with a 12f629...
    In fact my real program is more complex than this one but the pattern is the same. A switch control an action on 2 output pins instead of only one for this program.
    That program is suposed to turn on a LED(GP2) with a ground applied to port GP0 and turn off the LED(GP2) if a 5V is applied on the GP0.
    Let me know is someone find some problem?? I've already try many way...but the program seems to be very simple...and probably there are something that I've forget to do.
    thanks
    Martin
    martarse's Avatar
    martarse Guest
    Thumbs up Problem resolved
    I've read in the PBP Manual...the new version (2004)...my version was from 2002...that for pic micro with comparator (like the 12f629) we have to add a line to the program header.
    CMCON = 7
    This line is used to inform the Picmicro to use GPIO comparator pins as a digital pin.
    Everything works good for now!
    thanks! hihi!
    Hope this will help!
    byebye
    Salut Martin!
    always great to know somebody find it by himslef
    this link could be kind of interest for some.
    martarse's Avatar
    martarse Guest
    Default Thanks
    allo Steve,
    Thanks for this link.
    Sep 2003
    INDIA
    Default GR8 Link Steve
    Thank you for the URL's
    Rentron is even my favourite site. Learnt a lot from both the sites.
    regards
  1. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 11:16
  2. Weird Problem
    By isaac in forum General
    Last Post: - 22nd September 2008, 19:30
  3. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 09:53
  4. PIC18F got some weird problem?
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 16:18
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 01:08
