Maximum frequency count on 16F628/4MHz
Results 1 to 11 of 11
    Hi solara,
    You had specified Timer1, which is slower than Timer0.
    If you use Timer0, you can measure up to 50Mhz, even with a 4Mhz osc.
    Using the Prescaler, it actualy works like a 16-bit Counter. It's a little tricky to get the lower 8-bits. But it can be done.
    Check out AN592 from Microchip
    AN592: Frequency Counter Using PIC16C5x
    HTH,
       Darrel
    solara's Avatar
    solara Guest
    Thanks Darrrel,
    Thats what I wanted to hear.
    solara's Avatar
    solara Guest
    Looks like TMR0 is still bound by the same limits as TMR1 on 16F628 (according to datasheets).
    Also the AN592 doc is only for PIC 16CXXX, which can measure up to 50MHZ.
    solara's Avatar
    solara Guest
    Just had another more detailed browse at the 16F628 sheets, and see that with prescaler the high and low pulse widths are min 10ns. Implying period=20ns = 50MHZ.
    Thanks everyone.
    Wink
    Hi, solara
    It works ...
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 04:52
  2. Can't get COUNT to count
    Last Post: - 23rd March 2009, 23:14
  3. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 22:41
  4. Frequency Counter
    By Asmith in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 15:54
  5. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 16:22
