Maximum frequency count on 16F628/4MHz
Results 1 to 11 of 11
    solara's Avatar
    solara Guest
    I should have mentioned this is an external asynchronous clock signal, which is being measured.
    Datasheet, Table 17-7, Parameters 45, 46 & 47. These values are independent of actual Processor Clock Speed.
    solara's Avatar
    solara Guest
    For an asynchronous external clock on a 16F628
    45=30ns
    46=30ns
    47=60ns
    This doesnt help me as there is no specified minimimum rise and fall times.
    And from the figures above 45+46+rise+fall=47.
    solara's Avatar
    solara Guest
    Is this saying that the maximum external asynchronous clock frequency is 1/60ns =16 MHZ?
    Sounds far too low.
    That's what it's telling you. If you don't believe it, take a signal generator and run a test. The PIC isn't exactly a speed demon.
    Hi solara,
    You had specified Timer1, which is slower than Timer0.
    If you use Timer0, you can measure up to 50Mhz, even with a 4Mhz osc.
    Using the Prescaler, it actualy works like a 16-bit Counter. It's a little tricky to get the lower 8-bits. But it can be done.
    Check out AN592 from Microchip
    AN592: Frequency Counter Using PIC16C5x
    HTH,
       Darrel
    solara's Avatar
    solara Guest
    Thanks Darrrel,
    Thats what I wanted to hear.
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 23:41
  4. Frequency Counter
    By Asmith in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 16:54
  5. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 17:22
