ds1307
Results 1 to 8 of 8
Thread: ds1307
    Jun 2006
    Default ds1307
    I'm trying to read a ds1307 using code that Bruce wrote but it will only show 00:00:00 for time & date. I'm using real pic simulator. Do I blame it on simulator & go on?
    ' Note: use 10K pull-up resistors on both SDA and SCL lines.
    ' DS1307 control pins
    SDA Var PORTB.0 ' DS1307 SDA pin #5
    SCL Var PORTB.1 ' DS1307 SCL pin #6
    ' Variables
    DB       Var BYTE[8] ' Data byte array
    RTCSec   Var DB[0]   ' alias individual bytes in array
    RTCMin   Var DB[1]
    RTCHour  Var DB[2]
    RTCDay   Var DB[3]
    RTCDate  Var DB[4]
    RTCMonth Var DB[5]
    RTCYear  Var DB[6]
    RTCCtrl  Var DB[7]
    AMPM     Var BIT
    AM       Con 0
    PM       Con 1
    ' Port configuration
    TRISB   =   0
    TRISA   =   0
    CMCON   =   %00000111 ' Comparators = off
        ' 12-hour mode clock routine for the DS1307 RTC
        GOSUB Write_1307 ' Write time & date on power-up
        GOSUB Read_1307  ' Read the time & date
        ' Now display it
        HSEROUT ["Time: "]
        HSEROUT [DEC((RTCHour>>4)& $01), DEC(RTCHour & $0f),":"]
        HSEROUT [DEC((RTCMin>>4)& $0f), DEC(RTCMin & $0f),":"]
        HSEROUT [DEC((RTCSec>>4)& $0f), DEC(RTCSec & $0f)]
        AMPM = RTCHour.0[5] ' Bit 5 of RCTHour indicates AM or PM
        IF AMPM = AM THEN        ' If RTCHour.bit5 = 0 it's AM
           HSEROUT [" AM",13,10] ' Print AM
        ELSE                     ' Else it's PM
           HSEROUT [" PM",13,10] ' Print PM
        HSEROUT ["Day: ", DEC(RTCDay & $07),13,10]
        HSEROUT ["Date: ", DEC((RTCMonth>>4)& $01), DEC(RTCMonth & $0f),":"]
        HSEROUT [DEC((RTCDate>>4)& $03), DEC(RTCDate & $0f),":"]
        HSEROUT [DEC(((RTCYear>>4)& $0f)*100),DEC(RTCYear & $0f),13,13,10]
        PAUSE 1000
        GOTO Main
    Read_1307:
        ' Read order is in Secs,Mins,Hours,Day,Date,Month,Year,Control
        I2CRead SDA,SCL,$D0,$00,[STR DB\8]  ' Read string of 8 bytes from DS1307
    Write_1307:
        ' $71 in the Hours register would make it 11 PM
        ' $51 in the Hours register would make it 11 AM
        ' Example:
        ' $51 = %0101 0001 <-- 1's position of hour
        '        ||||_________ 10's position of hour. 10+1 = 11 O-clock
        '        |||__________ 1 = PM, 0 = AM (in 12-hour mode)
        '        ||___________ 1 = 12-hour mode, 0 = 24-hour mode
        '        |____________ ignore this bit
        ' Set time & date to  11:59:00, Day 2, Date:Month:Year 30:08:2007
        I2CWRITE SDA,SCL,$D0,$00,[$00,$59,$51,$02,$30,$08,$27,$90] ' Write to DS1307
        RETURN                  ' Sec Min  Hr Day  D   M   Y  Control
    Default Re: ds1307
    I don't know anything about that simulator, but that code seems to work fine in the Proteus Simulator with a 16F88.
    What chip are you using?
    Jun 2006
    Default Re: ds1307
    I'm using a 16F690. I have never used any rtc's at all so don't know if my simulator will do this. It does have a rtc ds1307 in it though. My simulator is keeping time off the computers time.This is my chip set up:
    TRISC   =   %00000000
    TRISB   =   %00000000
    TRISA   =   %000000
    CM1CON0.7 =  0 ' Comparators = off
    CM2CON0.7 =  0 ' Comparators = off
    ANSEL   =   %00000000
    ANSELH  =   %00000000
    Default Re: ds1307
    The code specifies PORTB.0 and PORTB.1 as SDA and SCL.
    But the 16F690 doesn't have either RB0 or RB1, it only has RB4-RB7.
    What pins are the DS1307 connected to in your simulation?
    Jun 2006
    Default Re: ds1307
    SDA to PORTA.0 & SCL to PORTA.1 sorry forgot to post that also.
    Default Re: ds1307
    Using a 16F690 with the changes you posted ... It still works.
    I can't comment on the simulator you are using.
    But I think you can assume the problem is not in Bruce's code.
    Jun 2006
    Default Re: ds1307
    Thanks Darrel really thought it was my simulator, now I know that. Thanks again, will look more into how this works with my simulator or if I'm just SOL.
    Dec 2012
    Default Re: ds1307
    Some simulators wont set the time automatically to system time, Ive run into this in the past, but just have your PIC chip check the time on startup and if it's all 0s, have it set the time through the code to a certain time or date. They do that for more realistic hardware, just like as if you were to hook up a blank ds1307 chip up and just started using it.
  1. DS1307 RTC example
    By malc-c in forum Code Examples
    Last Post: - 12th November 2012, 20:56
  2. ds1307
    By jonas2 in forum Code Examples
    Last Post: - 2nd November 2009, 10:50
  3. ds1307 i2c
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 13th June 2008, 16:26
  4. DS1307 help
    By Orlando in forum mel PIC BASIC Pro
    Last Post: - 17th March 2005, 16:17
  5. Ds1307
    By miniman in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 09:29
