Help Needed with Darrel's Interrupt on Change Routine
Results 1 to 6 of 6
Threaded View
  1. #3
    Default Re: Help Needed with Darrel's Interrupt on Change Routine
    In the case of IOCIF, the hardware does not allowing clearing that bit.
    As long as any of the IOCAF or IOCBF are set, the IOCIF bit will remain set too.
    DT_INTS does not clear the IOCAF or IOCBF flags, since there's no way to know which of the 16 flags should be cleared for your application.
    It is up to you to clear those flags.
    This particular chip doesn't have an IOCAF register, so ...
    In your case, ... IOCBF = 0 will fix your problem.
  1. incPID Routine - Help Needed
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 26th September 2013, 12:31
  2. Help needed with ADCIN Averaging Routine
    Last Post: - 24th December 2012, 16:05
  3. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 19:53
  4. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 01:57
  5. Darrel's Averaging Routine
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 27th June 2008, 23:24
