Hello Atodos a happy 2013 to all can someone help me
Results 1 to 6 of 6
    Bombay, India
    Default Re: Hello Atodos a happy 2013 to all can someone help me
    Unfortunately, there is no way you can know when the key has stopped. So, you have 2 alternatives
    1 - Let each command run for a small fraction of time before going back to prog
    example
    FRT:
         HIGH 4
         HIGH 6
         LOW 4
         LOW 6
    GOTO PROG
    2 - Put a timeout. So, if Serin does not give you a character, turn off all outputs
    SERIN PORTA.0,T9600, 1000, Timeout, RX
    Timeout:
       LOW 4
       LOW 5
       LOW 6
       LOW 7
    goto PROG
    This is from the manual
    An optional Timeoutand Labelmay be included to allow the program
    to continue if a character is not received within acertain amount of time.
    Timeoutis specified in 1 millisecond units. If the serial input pin stays in
    the idle state during the Timeouttime, the program will exit the SERIN
    command and jump to Label
    Aug 2008
    Hello Jerson
    Thanks for the reply
    I made the example 2 it more of a lock works very well.
    look at the video
    thank you
    Bombay, India
    Nice video.
  1. Happy New Year........
    By lester in forum Off Topic
    Last Post: - 1st January 2013, 03:17
  2. Happy New Year!
    By tacbanon in forum Off Topic
    Last Post: - 1st January 2013, 01:47
  3. Happy new year!
    Last Post: - 31st December 2012, 16:10
