A way to define specific ports for output bits? start output in middle port?
Results 1 to 12 of 12
    Dec 2012
    Tennessee
    Default Re: A way to define specific ports for output bits? start output in middle port?
    heres a copy of an sample program code needs to be fixed, think of it lighting 3 led's in binary sequence
    PORTB.0 = INT ' Just a INT Code Placeholder
    X VAR Byte : X = 0
    MyLOOP:
    PORTB.1-3 = X ' Shifting Code Needed
    X = X + 1
    if X > 7 then X = 0
    Goto MyLoop
    First of all, there's an error in my previous example. The shift left operator is of course << and nothing else, sorry about that. The "edit window" is closed so I can't go back and fix it.
    With your code as an example, try this:
    MyLoop:
      Temp = PortB & %11110001
      PortB = Temp | (X << 1)
      X = X + 1
      IF X > 7 THEN X = 0
      PAUSE 1000
    Goto MyLoop
    Lets go thru the two first lines:
    Temp = PortB & %11110001 - This reads the state of PortB into a variable called Temp and ANDS it with the value 14. What's happening there is that Temp will be whatever PortB is except for bits 1-3 which will be cleared to 0.
    PortB = Temp | (X << 1) - This takes the value of Temp and ORs with the value of X shifted one "step" to the left. Remember that Temp is a copy of what PortB was except bits 1-3 which are now 0. So if X is 3 (%00000011) PortB will be %xxxx011x where x is whatever was there before because X is shifted one "step" before ORing it with Temp.
    When doing a bitwise AND on two numbers each bit must be '1' in BOTH numbers for the bit to be '1' in the "result. So when doing a bitwise and with a value where certain bits are '0' those bits will be '0' in the result, example.
    %11111111 & %00000000 = %00000000
    %11111111 & %11110000 = %11110000
    %11001000 & %00001111 = %00001000
    When doung a biteise OR on two numbers it's enough that a bit in either number is '1' for that bit to be '1' in the result, example:
    %11111111 | %00000000 = %11111111
    %00000000 | %00001111 = %00001111
    %11110000 | %00001111 = %11110000
    So in the above code we read in PortB, clear bits 1-3 and put the value of X in those 3 bits.
    just some MORE browsing job ...
    http://www.picbasic.co.uk/forum/showthread.php?p=22065
    yes ... relevant threads already exist
    @#14 ... how to use Virtualport.bas
    Next step ???
  1. Changing bits in a byte for multiple output
    By tazntex in forum Serial
    Last Post: - 11th August 2008, 20:10
  2. Replies: 5
    Last Post: - 30th April 2008, 21:01
  3. 28 bits --> DEC output on LCD
    By SteveB in forum mel PIC BASIC Pro
    Last Post: - 1st August 2006, 20:33
  4. Serial Output 10 Bits
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 03:14
  5. Duplicating port input to port output
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 22:43
