cds on 16f877a
Results 1 to 3 of 3
Thread: cds on 16f877a
    chip_1's Avatar
    chip_1 Guest
    Default cds on 16f877a
    Hi all,
    on 16F84A this code works fine.
    v1 var byte
    pot portb.0,255,v1 ' connect an CDS (fotoresistor)
    if v1 < 230 then led
    led:
    high portd.1
    low portd.1
    on 16F877A no works!!
    why?
    thx
    chip_1
    Chip_1, I beleive the resistance of CDS Photoresistors are quite high as I remember. If the resistance you are encountering is much more than say 50k Ohms then the pot command will not work. You could possibly use the RCTIME command instead with and appropriate capacitor.....
    Or using the internal analog to digital converter with a op-amp[ buffer between CDS and the PIC.
    Be sure you place a 0.1 uF capacitor close to your PIC.
    Is anything else work with this PIC?
  1. 16F877A with 20MHz XTAL not working?
    By ustredna in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 16:04
  2. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  3. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 07:52
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
