Running a PIC16F628a on 3 Volt Power Supply
Results 1 to 4 of 4
    Default Running a PIC16F628a on 3 Volt Power Supply
    I have a PIC16F628a that I want to run off a 3 Volt supply (3V 2032 lithium battery). The PIC works as expected at 5 Volts supply, but when I drop the supply below 4.5 Volts the PIC stops working. The data sheets say this PIC should operate on as low as 2.0 Volts DC supply.
    Is there something I am missing??
    Help!
    Thanks, Russ
    Aug 2005
    Default Re: Running a PIC16F628a on 3 Volt Power Supply
    Have a read of page 136 and onwards of the data sheet for this part,this may be your issue.
    Hope it helps Sphere.
    Dec 2012
    I have a 16f628a running at 3v also and it works fine.(2 AA batteries) As the datasheets show, they wont run above 4Mhz if run at lower voltages. If your trying to run it on a 20Mhz crystal, that may be your problem.
    Thanks all, it appears the Brown-Out was enabled preventing operation below 4.3VDC.
    Turned it off per Darrel's suggestion and "presto" all is fine!
    But good points on the max frequency based on voltage. Good to keep in mind. Fortunately I am running at 4MHz. :-)
  1. power supply help ?
    By iugmoh in forum Schematics
    Last Post: - 27th February 2009, 21:01
  2. Backup Power Supply
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 20:37
  3. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
  4. 1.5 volt power.
    By Ron Marcus in forum Off Topic
    Last Post: - 8th December 2006, 16:21
  5. 12V Power Supply
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 21st May 2004, 01:46
