Help with multiple ADC inputs
Results 1 to 7 of 7
    Default Re: Help with multiple ADC inputs
    Not sure what is going on with your setup, I do not see the problem.
    I dug out a board with an 18F2550 and ran the below code to make sure it works. I only have the ADC on channels 1 and 2 as I have a LED soldered on channel 2. Other than that it should all be the same.
    '<FL_PIC18F2550>'
        '<FL_PBPL>'
        DEFINE OSC 48
         __CONFIG   _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
         __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
         __CONFIG   _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
         __CONFIG   _CONFIG2L, _PWRT_ON_2L & _VREGEN_ON_2L
         __CONFIG   _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
         __CONFIG   _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
        CNT VAR BYTE
        ADCON2.7 = 1
        ADCON1 = %00001101
        TRISA = %00000011
        DEFINE ADC_BITS 10
        DEFINE ADC_SAMPLEUS 50
        ADC_0   VAR WORD
        ADC_1   VAR WORD
        START:
        CNT = CNT + 1
        Serout2 PORTC.6, 16572, ["TEST ",DEC3 CNT, $d, $a]
        Serout2 PORTC.6, 16572, ["ADC_0 ",DEC4 ADC_0, $d, $a]
        Serout2 PORTC.6, 16572, ["ADC_1 ",DEC4 ADC_1, $d, $a]
        TOGGLE PORTA.2
        PAUSE 1000
        GOSUB GET_ADC
        GOTO START
        GET_ADC:
        ADCIN 0, ADC_0
        ADCIN 1, ADC_1
    Dec 2012
    Tennessee
    I got it to work by leaving off the adcon.7 code, heres what I am using for 2 ADC, it works great, if I change the adcon.7 it wont even compile
    DEFINE ADC_BITS 10 ' A/D number of bits
    DEFINE ADC_CLOCK 1 ' Use A/D internal RC clock
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in us
    ADCON1 = %10000000
    TRISA = %00000011 'PORTA 0&1 is input
    SETT Var Word ' A/D converter result in 10bit
    READT var word ' A/D converter result in 10bit
    AGAIN:
    ADCIN 0, READT ' Read Channel 0 data
    ADCIN 1, SETT ' Read Channel 1 data
    ADCON.7 will not compile because it is a wrong command. You need to use ADCON2.7=1
  1. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 16:13
  2. Can't get RA0 to read inputs?!?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 17th December 2007, 21:46
  3. dip switchs & inputs
    By grounded in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 14:37
  4. Many Analog Inputs
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 10th July 2006, 09:15
  5. multiple serial inputs
    By Richardco in forum mel PIC BASIC
    Last Post: - 25th November 2005, 22:26
