Not sure what is going on with your setup, I do not see the problem.
I dug out a board with an 18F2550 and ran the below code to make sure it works. I only have the ADC on channels 1 and 2 as I have a LED soldered on channel 2. Other than that it should all be the same.
Code:'<FL_PIC18F2550>' '<FL_PBPL>' DEFINE OSC 48 #CONFIG __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H __CONFIG _CONFIG2L, _PWRT_ON_2L & _VREGEN_ON_2L __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L #ENDCONFIG CNT VAR BYTE ADCON2.7 = 1 ADCON1 = %00001101 TRISA = %00000011 DEFINE ADC_BITS 10 DEFINE ADC_SAMPLEUS 50 ADC_0 VAR WORD ADC_1 VAR WORD START: CNT = CNT + 1 Serout2 PORTC.6, 16572, ["TEST ",DEC3 CNT, $d, $a] Serout2 PORTC.6, 16572, ["ADC_0 ",DEC4 ADC_0, $d, $a] Serout2 PORTC.6, 16572, ["ADC_1 ",DEC4 ADC_1, $d, $a] TOGGLE PORTA.2 PAUSE 1000 GOSUB GET_ADC GOTO START GET_ADC: ADCIN 0, ADC_0 ADCIN 1, ADC_1 RETURN
