Help Needed with Darrel's Interrupt on Change Routine
Results 1 to 6 of 6
    Jan 2011
    Sydney, Australia
    Default Help Needed with Darrel's Interrupt on Change Routine
    Hi All,
    I have been going around in circles all day trying to get Darrel's Instant Interrupt routine (Interrupt on Change) working on two PORTB pins of a PIC16F1826. I want to increment or decrement a byte size variable (Level) between 1 and 8 using switches on RB1 and RB2. Each pin has a 10k pull down resistor and I have tried to set the IOCBP register to read rising edge triggers. The variable is displayed on a 16 x 2 LCD using LCDOUT command. I can display the variable (default is 3) but cannot get the switches to work.
    My code is as follows:
        __config _CONFIG1,    _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
        __config _CONFIG2,    _WRT_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_25 & _LVP_OFF
    DEFINE OSC 32                       'Internal RC Oscillator with PLL
    ' Connect LCD DB4 to RA0 (Pin 17)
    ' Connect LCD DB5 to RA1 (Pin 18)
    ' Connect LCD DB6 to RA2 (Pin 1)
    ' Connect LCD DB7 to RA3 (Pin 2)
    ' Connect LCD R/S to RA6 (Pin 15)
    ' Connect LCD E   to RA7 (Pin 16)
    ' Connect Reset Button to MCLR (Pin 4)
    ' Connect Up Switch to RB1 (Pin 7) with 10k pulldown resistor
    ' Connect Down Switch to RB2 (Pin 8) with 10k pulldown resistor
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INT_LIST macro             ; IntSource,        Label,  Type, ResetFlag?
        INT_Handler    IOC_INT,  _PortBInterrupts,   PBP,  yes
    @    INT_ENABLE   IOC_INT     ; enable PortB change interrupts
    Define	LCD_DREG	PORTA
    Define	LCD_DBIT	0
    Define	LCD_RSREG	PORTA
    Define	LCD_RSBIT	6
    Define	LCD_EREG	PORTA
    Define	LCD_EBIT	7
    Define	LCD_BITS	4
    Define	LCD_LINES	2
    INTCON = %10001000                  'Enable Global Interupts and IOC interrupt
    OSCCON= %11110000                   'PLL enabled, Internal RC-8MHz and PLL x 4
    CM1CON0.7 = 0   		            'Disable comparator 1
    CM2CON0.7 = 0                       'Disable comparator 2
    PORTB = 0:PORTA=0                   'Set all outputs to 0
    TRISB = %00000110                   'Set PORTB.1 & 2 as digital input
                                        'All other PORTB pins as digital outputs
    TRISA = %00100000                   'Set PORTA.5 as digital inputs
                                        'All other PORTA pins as digital outputs
                                        '(PORTA.5 can only be an input)
    ANSELA = %00000000                  'Disable PORTA analog inputs
    ANSELB = %00000000                  'Disable PORTB analog inputs
    ADCON0 = %00000000                  'Enable ADC and select AN9
    FVRCON = %00000000                  'Disable FVR
    IOCBP = %00000110                   'Set IOC on rising edge for RB1 & RB2
    IOCBN = 0                           'Disable IOC falling
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    Level   var     byte                'Level setting 1 - 8
    Level = 3                           'Set starting level to 1
    pause 1000                          'Pause 1 second
    LCDOUT $FE, 1                       'Clear screen
    Again:
        lcdout $FE, $80, "Level = ", dec Level, "      "'Display Level
        goto Again
    PortBInterrupts:
        if IOCBF.1 = 1  then
            Level = Level + 1
            If Level > 8 then
                Level = 8
        if IOCBF.2 = 1  then
            Level = Level - 1
            If Level < 1 then
                Level = 1
    @ INT_RETURN
    I have used the Instant Interrupt routine before (with some help from other forum members) but this time it has me perplexed. The process of commenting out variable wsave etc confuses me as on this occasion the compiler gives no error messages. I have tried a number of different combinations - all to no avail. I must admit, I have been clutching at straws for the last few hours!
    Can somebody please look at the code and tell me what I am doing wrong?
    Cheers
    Barry
    VK2XBP
    Default Re: Help Needed with Darrel's Interrupt on Change Routine
    One thing with IOC is that you need to read the port in the ISR to clear the mismatch condition. This chips IOC feature seems a bit more complicated than the "standard" though and it looks like you don't actually have to do it but I'm not 100% sure.
    Being different than the IOC implementation on older chips it's possible that the Instant Interrupt Routines doesn't handle this new IOC implementation properly. I'm not saying that is the case but it's possible. Hopefully Darrel sees this and will set the record straight.
    I don't have any of these new 16F1xxx chips so I can't test but one thing you can try is to manually clear the IOCBF.1 or IOCBF.2 bits before exiting the interrupt service routines.
    In the case of IOCIF, the hardware does not allowing clearing that bit.
    As long as any of the IOCAF or IOCBF are set, the IOCIF bit will remain set too.
    DT_INTS does not clear the IOCAF or IOCBF flags, since there's no way to know which of the 16 flags should be cleared for your application.
    It is up to you to clear those flags.
    This particular chip doesn't have an IOCAF register, so ...
    In your case, ... IOCBF = 0 will fix your problem.
    Jan 2011
    Sydney, Australia
    So close and yet so far....
    Thanks for the input guys. I added the IOCBF=0 line to the ISR and, after adding a slight pause to debounce the switch, all is now working properly.
    Two things confuse me though:
    1/. Without the IOCBF=0 statement, why didn't my initial code get to the ISR the first time a switch was pressed? I would have expected the ISR to be called once (changing Level from 3 to 4 or 3 to 2 depending which switch was pushed) but then halting due to the IOCBF not being reset.
    2/. What should I expect regarding the commenting-out of the variables (wsave etc) when first compiling the Instant Interrupt routine? It compiles with all lines commented out. Is this right and if so, why?
    Cheers
    Barry
    VK2XBP
    1. It would have called the ISR the first time.
      But it would have never made it back to the main program to display the change.
      As soon as it exits the ISR, it immediately triggers an interrupt again because the flag wasn't cleared.
    2. The 16F1's do automatic context saving.
      You do not need any wsave variables.
      Which is why it didn't tell you to uncomment any of them.
    Jan 2011
    Sydney, Australia
    Thanks Darrel.
    I understand now.
    Onwards and upwards! Time to add your Elapsed Timer routine to this project
    Cheers
    Barry
    VK2XBP
  1. incPID Routine - Help Needed
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 26th September 2013, 13:31
  2. Help needed with ADCIN Averaging Routine
    Last Post: - 24th December 2012, 17:05
  3. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 20:53
  4. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  5. Darrel's Averaging Routine
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 00:24
