Analog Digital Conversion ??
Results 1 to 4 of 4
    Dec 2012
    Türkiye
    Default Analog Digital Conversion ??
    Hi , I'm new in this forum , and to the pic programming too ...
    I was trying to understand a code already written by an anonymous programmer to manage an ADC of a PIC ..
    But there is that part of which function that I can't understand , particularly consisting a mathematical code ...
    BTW It's basically a voltmeter measuring the voltage on a connected pot or sth
    Here is the program ;
    TRISA=000001
    TRISB=0
    TRISC=0
    TRISD=0
    @ DEVICE pic16F877
    @ DEVICE pic16F877, WDT_on
    @ DEVICE pic16F877, PWRT_ON
    @ DEVICE pic16F877, PROTECT_OFF
    @ DEVICE pic16F877, XT_OSC
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD RWREG PORTB
    DEFINE LCD_RWBIT 2
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 100
    ADCON1=001110
    HAM var word
    VOLT var word
    MVOLT var byte
    LOW PORTB.2
    LCDOUT $FE,1
    PAUSE 200
    START:
    ADCIN 0,HAM
    CTRL:
    IF ADCON0.2=1 THEN CTRL
    LCDOUT $FE,1," HAM =",# HAM
    HAM=HAM+1
    VOLT=(HAM*/ 1250)/100
    MVOLT=VOLT // 10
    VOLT=VOLT/10
    LCDOUT $FE,$C0," VOLT=",#VOLT,",",# MVOLT
    PAUSE 500
    GOTO START
    The part that I don't understand is the code scripted as below ;
    HAM=HAM+1
    Volt=(ham */ 1250)/100
    Mvolt=Volt // 10
    Volt=Volt/10
    NOW HERE ARE MY QUESTIONS ;
    1. Where does this decimal "1" come from and why do we add it to the "ham" variable
    2. Where does this 1250 , 100 come from ?
    3. What are these operators written as "//" and "*/"
    I'd be so appreciated if you could help me with these ....
    Thanks in advance ...
    Miami, Florida USA
    Default Re: Analog Digital Conversion ??
    Welcome to the forum. The operators "*/" and "//" can be found in the 'Math Operators' section of the PBP manual.
    http://melabs.com/resources/pbpmanual/
    Now, about your other questions, many of us don't have the good habit of writing a good comment after every line of code. So, I am not sure what the programmer wanted to do there. Maybe somebody else here has a better answer.
    Anonymous
    If we knew what this code was written for we might be able to answer your other questions, but random code ...
    May 2008
    Italy
    1 is clearly an offset. The reason for using it is unknown, it could depend on the necessity to alline the reading with other device
    1250 is a coefficient for converting the ADC reading into volts. The actual coefficient should be 12.5 but due to the integer math limitation the author did multiply it by 100 to obtain 1250 and then he devide the product by 100.
    All these numbers are related to a specific application, so you should ignore them, since very likely, your application will require different numbers as coefficient and eventually an offset.
    Cheers
    Al.
  1. analog and digital
    Last Post: - 10th June 2008, 02:40
  2. digital to analog conversor
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 20:46
  3. PortA analog and digital IO
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 30th November 2007, 02:25
  4. Digital to Analog Converter
    By kutsi in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 19:17
  5. Replies: 2
    Last Post: - 14th April 2006, 09:42
