Syntax error
Results 1 to 3 of 3
Thread: Syntax error
    Default Syntax error
    Can anyone tell me what is wrong with this ...
    hserout [hex2 S[(((L-1)*8)+cnt)]]
    It throws a compiling error "Expected ']' or ')']'
    Syntax error
    There are equal numbers of brackets...?
    MW
    Default Re: Syntax error
    That just looks wrong....What's it supposed to do?
    I don't think you should use square brackets "inside" the actual statement, only enclosing it - and perhaps there's a missing comma?
    HSEROUT [hex2 S, (((L-1)*8)+cnt)]
    But again, not easy to say withoyt knowing what's it supposed to do.
    Hi - Thanks for your reply. Tried it again having replaced all but the outermost brackets with ( or ) and it has fixed it. Of course, now I get some different errors. Haven't a clue what I'm doing really! If I get stuck again "I'll be back!" as they say. It's a bit of a steep learning curve after VB6. MW
  1. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 05:14
  2. syntax error
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 21st February 2010, 22:06
  3. syntax error
    By Gerd in forum mel PIC BASIC Pro
    Last Post: - 8th June 2008, 02:49
  4. 16F819 syntax ERROR
    By k-hirayama in forum mel PIC BASIC Pro
    Last Post: - 5th February 2008, 01:40
  5. OPTION_REG = $7f syntax error
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 21:05
