controller Charge Pump?
Results 1 to 26 of 26
    toalan's Avatar
    toalan Guest
    I have not seen the additions you have made on the PDF because the current computer I use gives an error with the file, I will look at it later on a nother computer.
    I pretty much understand how the circuits works. I have made a citcuit long time ago that was very similar to what the Bosch ICs are doing. That was with analog circuits right now I am trying to do most of the Analog stuff using a MCU so to minimize tolerance problems and to cheapen things up and also to add dataloggin capabilities to it.
    I built my first circuits based on the Bosch Datasheet for the Sensor itself because I never knew the Datasheets for the ICs existed publicly. The circuit I built before knowledge of the Cj120 datsheet was similar in many ways to the CJ120 but more simplier. Now that I seen the CJ120 the only thing I can not understand is on Page 3 or 4 of the CJ120 PDF, the use of Rical (82 ohms). The fact that I can not speak German only adds to the problem. But I am sure somewhere in my subconcious my mind is solving the issue, so it will only be a matter of time before I know what the RiCal does. I suspect it maybe a reference restance that the resistor in the pump Cell (Ri) should be at during normal operations. The reason I say this is becasue I know pretty sure that the Pump resistance should be close to 80 ohms during normal operation and not the 100 ohms that is shown on the diagram.
    There is no need to simulate the BOSCH LSU sensor in my testing since I have about 4 of them lying around. Also the Pump current goes through an external 61.9 resistor, I suspect the 100 ohms you are talking bout is the internal resistance of the pump cell.
    I would love to by the bosch ICs from rutronik but they require huge quantity purchases something in the thousands per order.
    If I can digitize most of the analog circutry I can make a very cheap, fast and accurate Wideband reader.
    toalan's Avatar
    toalan Guest
    BTW Luciano TY very very much for posting up the documents, because of the new information I found in there I am going to make a few design adjustments to my circuits and MCU program.
    Italy
    My previous post:
    The PDF was not modified. You will have to draw the two op-amp's
    and their connections on page 4. The 100 ohm resistor on the output
    of the op-amp "Pump current control" is present in the Tech Edge circuit.
    The CJ120 also measures the Nernst-cell internal resistance (Ri) which
    is used to determine the temperature of the sensor. The internal resistance
    of the Nernst-cell is 80 ohm when the sensor ceramic temperature is approx. 750°C.
    By knowing the (Ri) you can control the heater supply voltage so that the
    temperature of the sensor is kept at a nominal temperature of approx. 750°C
    which is needed for *precise* measurements.
    The Nernst-cell internal resistance is measured by pulsing the Nernst-cell via a
    capacitor and a resistor.The pulsing must be done between 1kHz and 4kHz.(CJ120 3kHz).
    On the Tech Edge Pty. Ltd. schematic you can see that they measure the Nernst-cell
    internal resistance and also measure the effective heater voltage and current.
    On the CJ120 block diagram you can see that the effective heater voltage and
    current are not measured. The document http://wbo2.com/lsu/Y258K01005e03mar21eng.pdf
    describes the maximum permissible heat up rate when the heater is switched on.
    When you know the Nernst-cell internal resistance then you can control the heater
    without measuring its voltage and current.
    Luciano
    toalan's Avatar
    toalan Guest
    I have read the datasheet on the sensors many times before.
    My original circuit had PID control of heater to maintain the 80 ohm resistence on the nermest Cell with a 3 khz ac signal, I made a mistake in my previous post about the 80 ohms in the pump cell when it should of been the nermest cell.
    toalan's Avatar
    toalan Guest
    I just looked at the tech edge diagrams in detail, everythin looks fine a dandy except I did not notice a coupling capacitor to couple the 3 khz AC signal to sense the Nermest resistance, the "VsDrive" connection connects through a resistance (910 ohms) to pin 11 of the atmel8 AVR MCU, if you are coupling an AC signal of 0v to 5v then for the bosch lsu you would need something in the 10k range and also a capacitor. Also Pin 11 of the atmel8 AVR is not a PWM pin, if he is ouputing an AC signal he must be doing it via software.
    I am thinking that the TE unit actually powers off the sensor and does DC sensing of the the resistence in the nermest cell, which would make the unit super slow.
    I am jsut puzzled because no where on the schematic are any hallmarks of generating an ac signal, coupling an ac signal into the nermest cell, or low pass filtering to target a signal in the 3khz range. The only filtering around the VS port are low pass filters with a 3bd freq of about 10khz.
    Italy
    See attached BMP file.
    Nernst-cell internal resistance (Ri) measurement.
    The circuit measures the resistance of the Nernst-cell and
    also the resistance of the RiCall 82.5 ohm. Both measurements
    are done with the same I/O, so we measure with the same voltage
    when we source (+4.xx V) and when we sink (0.xx V).
    The PWM is not used.
    The AC current is ≤ 250 µA.
    (See 250 µA current direction when the I/O sink or source).
    The differential amplifier will output a voltage when
    Ri and RiCall have different values.The output voltage is
    measured with the A/D of the MCU. With the resistors you
    can adjust the gain of the amplifier.
    The Tech Edge does almost the same with the I/O but
    they use a 910 ohm resistor so the current is more
    than 250 µA. (???). The capacitor is the 100nF C201.
    They use 2V as the virtual ground.
    (See page 6 of the PDF for Max. current load of the Nernst-cell).
    This is just a theoretical circuit.
    Never been tested.
    Luciano
    toalan's Avatar
    toalan Guest
    910 ohms would mean they are violating 250ua parameter by more than 10 fold with a 0-5v signal, c210 looks like it is just part of a lowpass filter to remove noise rather than to couple an ac signal into the nermest cell.
    It looks to me that they really are powering off the sensor and doing a DC measurement of Ri. I also have no idea why they use an external DAC rather than the avaible PWM ports on the Atmega8 instead.
    Luciano are you affiliated with Tech Edge? are you also building you own Wideband reader? Why are you using RiCal of 82.5? I believe it is a reference resistance for the nermest cell, shouldn't it be 80 ohms?
    The way I am doing the Ri measurement is different as I try to use as little OP amps and resistors as possible and use a bit of digital signal processing instead.
  1. Microstepper controller
    By aratti in forum Schematics
    Last Post: - 3rd January 2015, 17:52
  2. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  3. an observation of the forum as a metaphor
    By duncan303 in forum Off Topic
    Last Post: - 6th February 2008, 14:59
  4. Metering pump
    By Steve_88 in forum Off Topic
    Last Post: - 18th January 2008, 15:04
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
