controller Charge Pump?
Results 1 to 26 of 26
    Sep 2003
    Vermont
    I need more info. Why a charge pump? What is your initial voltage? What is your needed voltage? I have run a 5 volt LCD screen from a 3 volt PIC using the PWM output. There are app notes for pushing out over 200 volts using a step up coil and diodes from a lowly PIC!
    I like coils for step up, but the EMI can be a problem. What is the application?
    Ron
    toalan's Avatar
    toalan Guest
    the application is a bit odd. it is to control an oxygen sensor is a car, basically i need to source enough charge such that the catylitic reaction in the oxygen sensor is at steady state.
    The amount of charge i need to pump in to reach that steady state is proportional to the amount of oxygen left over from internal combustion. it is this amount of oxygen that i am intersted in measureing. Most designs use voltage source pushing current through a small resistor to supply the current needed, and then use A/D to find to voltage drop across the resistor to find the steady state current.
    But I would like to do away with using A/Ds, if i had a way to use PWM to control a charge pump or current source that would make things alot simplier.
    I need something that I can control percisely to do the following:
    supply: -4ma to +4ma
    the voltage range of operation would be between -5V to 5V.
    I am a bit stuck in finding something, I can explain things in more detail if needed but basically I need a PWM controlled current source/charge pump, even a voltage controlled current source/chrage pump is okay, My only requirement is that the resolution and percision need to be high and it should not be very complex.
    Alan To
    Italy
    What about using a standard zirconium lambda sensor?
    Sensor output ranges from 0.2 Volts (lean) to 0.8 Volts (rich).
    A perfectly balanced or "stoichiometric" fuel mixture of 14.7 parts
    of air to 1 part of fuel gives an average reading of around 0.45 Volts.
    Luciano
    toalan's Avatar
    toalan Guest
    I am wokring with a wideband sensor and not the narrow band sensors.
    Italy
    toalan's Avatar
    toalan Guest
    that is the techedge one, I am not looking to "bite" his design. His design is overly complicated in my opinion.
    Italy
    Wink
    Feel free to "bite" the BOSCH design.
    (See the block diagram of the IC CJ110).
    But, doesn't it look familiar somehow?
    Luciano
    CJ110 - Lambda Probe Sensing IC for LSU4.
    http://www.semiconductors.bosch.de/p...y_extended.pdf
    CJ120 - Lambda Probe Sensing IC for LSU4.x
    Ri Measurement; SPI-Interface; Diagnostics
    Source:
    http://www.semiconductors.bosch.de/e...ine/engine.asp
    Bosch LSU 4.2 Planar Wide Band Lambda Sensor:
    http://wbo2.com/lsu/Y258K01005e03mar21eng.pdf
    eoasap's Avatar
    eoasap Guest
    Quote Originally Posted by Ron Marcus
    Ron
    Ron, how do you run a 5V LCD from a 3V PIC using PWM ? i'd love to try it out.
    Italy
    I have completely abandoned this project.
    Please do not send me private messages about this thread.
    Best regards,
    Luciano
  1. Microstepper controller
    By aratti in forum Schematics
    Last Post: - 3rd January 2015, 17:52
  2. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  3. an observation of the forum as a metaphor
    By duncan303 in forum Off Topic
    Last Post: - 6th February 2008, 14:59
  4. Metering pump
    By Steve_88 in forum Off Topic
    Last Post: - 18th January 2008, 15:04
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
