910 ohms would mean they are violating 250ua parameter by more than 10 fold with a 0-5v signal, c210 looks like it is just part of a lowpass filter to remove noise rather than to couple an ac signal into the nermest cell.
It looks to me that they really are powering off the sensor and doing a DC measurement of Ri. I also have no idea why they use an external DAC rather than the avaible PWM ports on the Atmega8 instead.
Luciano are you affiliated with Tech Edge? are you also building you own Wideband reader? Why are you using RiCal of 82.5? I believe it is a reference resistance for the nermest cell, shouldn't it be 80 ohms?
The way I am doing the Ri measurement is different as I try to use as little OP amps and resistors as possible and use a bit of digital signal processing instead.
