My previous post:
The PDF was not modified. You will have to draw the two op-amp's
and their connections on page 4. The 100 ohm resistor on the output
of the op-amp "Pump current control" is present in the Tech Edge circuit.
The CJ120 also measures the Nernst-cell internal resistance (Ri) which
is used to determine the temperature of the sensor. The internal resistance
of the Nernst-cell is 80 ohm when the sensor ceramic temperature is approx. 750°C.
By knowing the (Ri) you can control the heater supply voltage so that the
temperature of the sensor is kept at a nominal temperature of approx. 750°C
which is needed for *precise* measurements.
The Nernst-cell internal resistance is measured by pulsing the Nernst-cell via a
capacitor and a resistor.The pulsing must be done between 1kHz and 4kHz.(CJ120 3kHz).
On the Tech Edge Pty. Ltd. schematic you can see that they measure the Nernst-cell
internal resistance and also measure the effective heater voltage and current.
On the CJ120 block diagram you can see that the effective heater voltage and
current are not measured. The document http://wbo2.com/lsu/Y258K01005e03mar21eng.pdf
describes the maximum permissible heat up rate when the heater is switched on.
When you know the Nernst-cell internal resistance then you can control the heater
without measuring its voltage and current.
Luciano
