I2C question w/ MCP23017 Port Expanders
Results 1 to 6 of 6
    Default Re: I2C question w/ MCP23017 Port Expanders
    your pull-up are far to be correct... at slow speed they need to be 4.7K or so... around 1.8k at higher speed.
    Begin with it.
    thanks mister_e,
    i will give that a try but i have never had much sensitivity to their value on other projects, will report back
    my suspicion is that when pcb2 is not connected the lack of response after writing to it has something to do with the issue
    May 2006
    Del Rio, TX, USA
    The I2C protocol shouldn't work open loop. The slave must send an ACK after each byte that is written. I would be very surprised if the PBP routines for I2C were written in a way that did not wait for the slave ACK.
    Hi Steve
    my understanding is that if there is an error with the ACK the program can jump to a location specified by an optional LABEL, if the optional LABEL is not given then the error is ignored
    are there examples here somewhere how to use the on chip hardware for I2C ?
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 18:53
  2. 16F1847 Usart and I2C
    By Seahound1 in forum Serial
    Last Post: - 18th December 2012, 20:41
  3. Strange I2C and serial behaviour.......
    By jimbostlawrence in forum General
    Last Post: - 30th October 2012, 01:02
  4. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 14:01
  5. Question Regarding Port A on 16F876A
    By jevert in forum mel PIC BASIC Pro
    Last Post: - 26th February 2009, 14:00
