Do Loop
Results 1 to 14 of 14
Thread: Do Loop
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Do Loop
    i would not think its a problem , but you can always try using while wend loop see if changes the problem
    while dooropen <> 0
    wend
    Apr 2007
    Pennsylvania, USA
    Default Re: Do Loop
    Using while wend is a better method, but nothing shown here should cause your problem. Can you share all of your code? I had a similar issue by not exiting a subroutine properly, the program worked for a while then would eventually crash. It took me a while to pin point it.
    Shawn
    Feb 2012
    Default Re: Do Loop
    Shawn,
    Thanks for the reply. I do have a question concerning your answer. In the PBP manual it states the "While...Wend" has been deprecated and to use the "DO...Loop" instead. I never completely trust manuals because most become outdated with code updates. As such, I'd very much appreciate an elaboration as to why I should use the "While...Wend' when the manual states otherwise.
    Skybox
    May 2006
    Del Rio, TX, USA
    Default Re: Do Loop
    For what you are doing, you can also use this method:
    WaitForDoor:
        IF DoorOpen <> 0 THEN WaitForDoor
    Default Re: Do Loop
            WHILE DoorOpen : WEND
            '       or
            Repeat : Until !DoorOpen
            '       or
    SitAndSpin:  If DoorOpen then SitAndSpin
            '       or
            Do Until !DoorOpen : Loop
            '       or
            do : Loop WHILE DoorOpen
    As far as I'm aware of, PBP take care of the WatchDog timer, so it shouldn't be an issue...
    Feb 2012
    Default Re: Do Loop
    Thanks everyone for your assistance. The problem end up being associated with the LDR. I have the output of the LDR circuit going to the comparator of the PIC. The result is then assigned to a variable and subsequent code is used to make decisions. Here is a simplified example of my original code- VL is the variable.
    For I = 1 to 20
    Pause 500
    ADCIN 0, VL
    If VL => 300 then
    Light = 1
    Indicator LED = 1
    Endif
    If VL =< 100 then
    Light = 0
    IndicatorLED = 0
    Endif
    Next I
    My thinking was that I could bypass the threshold that exists in a LDR between light and dark by inserting a gap of 100 ( difference between 300 and 100) and a half second Pause in the For / Next loop. I used the For/Next loop count to 20 along with the Pause to ensue the light change was permanent and not from some errant source.
    This did work but during the time VL hovered around the threshold zone (between 300 and 100) I start receiving unpredictable results. If at the end of the 20 count the threshold was still present the program became confused and would open the door halfway, stop, and crash.
    So I changed the code to this:
    For I = 1 to 20
    Pause 500
    ADCIN 0, VL
    If VL => 300 then
    Light = 1
    Indicator LED = 1
    Else
    Light = 0
    IndicatorLED = 0
    Endif
    Next I
    This seems to work but only have one night of results but I'm optimistic.
    skybox
    Dec 2011
    IO93ok
    Default Re: Do Loop
    I did something similar for a chicken coop door and originally had problems with the ldr as well.
    I countered this and shadows etc by flipping a counter. Single microswitch and a small 12v model motor.
    This code worked well.
    '#  Automatic chicken coop sliding door.       #
    '#  12 Volt Battery powered.                   #
    '#  Open when light, close when dark.          #
    '#  Sleep 4 hours between to conserve power    #
    '#  and to prevent retriggering.               #
    '#  Uses single microswitch as feed back.      #
    '#  Pic 16f818 --- Rob Lane - Dec 2011         #
    OSCCON=$60                  'set 4mhz internal oscillator
                                '(Set INT_OSC in programmer fuses)
    ' Define ADCIN parameters
    Define	ADC_BITS	10  	'Set number of bits in result
    Define	ADC_SAMPLEUS	50	'Set sampling time in uS
    Photo   	var	word	   	'Create 'photo' to store result of ldr input
    Counter1    var byte        'flip flop counter variable
       'PIN ASSIGNMENTS
    LDR         var porta.0
    MotorUp     var portb.4
    MotorDown   var portb.5
    Switch      var portb.6
         Counter1=1         'Set counter for power up, door must
                            'be closed in daylight for startup.
         pause 5000
         TRISA=%00000001	' Set PORTA
         TRISB=%01000000    ' Set PORTB
         input switch
            ADCIN ldr, photo                 'read ldr adc value
            IF Photo <15000 Then checkup     'daylight
            IF Photo >30000 Then checkdown   'darkness
    		'sleep 300             'about 5 minutes low power
    	    goto Main
    checkup:
            if counter1=1 then up
    up:
            High MotorUp           'start motor up
       		pause 1000             'wait 1 sec so micro switch opens
    stopup:
       		if switch = 1 then pressedup 'check microswitch state
            goto stopup                  'check again till true
    pressedup:
            low motorup           'stop motor
       		Counter1=2            'flip flop counter for up/down of door
       		sleep 150
       		'sleep 14400          'sleep 4 hours
    checkdown:
            if counter1=2 then down
    down:
    	    high MotorDown                   'start motor down
    stopdown:
       		if switch = 1 then presseddown   'check again
            goto stopdown
    presseddown:
            low MotorDown
       		Counter1=1
       		sleep 150
       		'sleep 14400
    Apr 2007
    Pennsylvania, USA
    Default Re: Do Loop
    Quote Originally Posted by skybox View Post
    Shawn,
    Skybox
    I have found the while wend to always work, I know I had problems with the do loop, but that may have been something else causing the problem. Some of the other suggestions here look to be a better alternative to either of these anyways.
    Shawn
    Apr 2010
    Default Re: Do Loop
    I am not sure if this would help or not , but I did have problem with some simple code that I had included Do,Loop.
    The code worked fine when it was compiled using PBP3.0 but it did not work if it was compiled by PBP2.50B , which I had on an older machine.
    The problem was solved when I changed the Do,Loop section to GOTO , and then the result from both PBP3.0 and 2.50B worked flawlessly.
    Feb 2012
    Default Re: Do Loop
    Vett58,
    Thanks for the response. The problem end up being in how I had the LDR circuit constructed. The code was not the issue. Originally, I had the LDR in a configuration that turned on a transistor when light changed. This did not work well so I reconfigured it into a simple voltage divider fed into a comparator. This works much better especially with a potentiometer serving as a variable resistor in the divider.
    Happy holidays
    Apr 2010
    Default Re: Do Loop
    Vett58,
    Happy holidays
    It is good to hear that the problem is solved .
    Happy holidays to you too.
  1. FOR..NEXT Loop Bug?
    By MSapper in forum mel PIC BASIC Pro
    Last Post: - 12th April 2011, 02:04
  2. if ... then loop
    Last Post: - 10th November 2010, 00:08
  3. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  4. Help with loop
    By wildbilly in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2007, 17:59
  5. While LOOP
    By actionplus in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 15:59
