RTC run too fast
Results 1 to 3 of 3
    Sep 2009
    Default RTC run too fast
    I have PIC18LF46k80, with 32768Hz crystal on SOSC pin. i need 32 interrupts per second for other things.
    Shematic:
    PCB:
    ISR:
    DEFINE  INTHAND myint
        CONFIG SOSCSEL = LOW ;Low power mode SOSC
        etc...
        TMR1H = 252
        T1CON = %10001101
        T1GCON = 0
    myint
            Clrf BSR
            Btfss PIR1,0
            GOTO End_RTC
            Clrf PIR1
            Movlw .252 ; TMR1H=252
            Movwf TMR1H
            Bsf _PULL
            Movlw .141
            Movwf T3CON
            Movlw .255
            Movwf TMR3H
            Movlw .223
            Movwf TMR3L
            Bsf _TimeChanged,0
            Incf _Ticks,F
            Movlw .31  ;if ticks=32 then
            Cpfsgt _Ticks
            GOTO End_RTC
            Incf _Seconds,F
            Bsf _TimeChanged,1
            Clrf _Ticks
            Movlw .1
    etc...
    Crystal MH32768C datasheet:
    http://www.farnell.com/datasheets/1322434.pdf
    I think that problem is in capacitors for crystal. I upload schematic and pcb layout, it's probably ok, but...
    I tried to put capacitors from 10,12,22pF and result always is same. About 10s to much per day...
    PC clock(Internet time disabled) and mobile phone are my references.
    Any idea how to solve this??
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: RTC run too fast
Size:  50.5 KBMaybe this help ?!
    Sep 2009
    That is problem.. Because I can't sped few days adjusting cap...
    I remove C6, now clock are much slower... C5 is 22pF...
    I put 12pF on C5, and I will see result tomorrow.
    Is both capacitor needed or just one?
  1. Setting project RTC without switches
    By ardhuru in forum Bluetooth
    Last Post: - 17th October 2012, 15:20
  2. i need modification for this code as fast as possible
    By cool_guy4ever15 in forum Off Topic
    Last Post: - 30th June 2009, 02:09
  3. Help! sinking fast!
    By fowardbias in forum mel PIC BASIC Pro
    Last Post: - 31st May 2007, 20:39
  4. Programmer too Fast?
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 10:07
  5. A/D on 16F877. How fast can I go?
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 8th April 2004, 07:51
