PBP and DT_INTs problems
Results 1 to 3 of 3
    Default PBP and DT_INTs problems
    I'm not sure how many issues i actually have here but i'll list the symptoms...
    1) MCS compiles PBP files and then says cancelled once it's complete (i turned silent off so i KNOW it completed without error). Date time stamp on the hex file etc are updated. However, the new hex file does not contain the changes. tried deleting everything except the pbp file and it still contains the old code.
    2) DT_INTs does not jump to interrupt subroutine on 16F1824 when ether external int or IOC pin is toggled.
    '*  Name    : test.BAS                                                             *
    '*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 01/08/2011                                        *
    '*  Notes   : 16F1824                                                  *
    @ __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    @ __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_25 & _LVP_OFF
    Define  OSC				32						' Set clock speed
    OSCCON.7 = 1
    OSCCON.6 = 1
    OSCCON.5 = 1
    OSCCON.4 = 1
    OSCCON.3 = 0
    OSCCON.1 = 0
    OSCCON.0 = 0
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    TRISA = %11011111
    TRISC = 0
    PORTC = 0
            INT_Handler   INT_INT,    _UPDATE,    PBP,  yes
    OPTION_REG.6 = 1
    @   INT_ENABLE   INT_INT
    Default Re: PBP and DT_INTs problems
    Quote Originally Posted by comwarrior View Post
    And neither would any ON INTERRUPTs, ASM interrupts or simple IF PORTA.2 = 1 tests, since you haven't enabled Digital inputs on your Analog pins.
    Feb 2012
    PERTH AUSTRALIA
    old config with comments for the same size PIC as 16F1824 ( well close ) this is for 16F1825 , as a ref hope it may be useful
    cheers
     ' config for 16F1825
    ;----- CONFIG1 Options --------------------------------------------------
        __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_ON
    ;----- CONFIG2 Options --------------------------------------------------
        __config _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _BORV_HI & _LVP_OFF
     ' ---------- Set up DT_INTS-14 Routine for Instant Interupt handling   -----------
    INT_LIST macro	; IntSource  ,    Label    , Type, ResetFlag?
       INT_Handler TMR0_INT,_Timer0_Count,  PBP, yes      ; call Timer0_Count subroutine
       INT_Handler  IOC_INT,_GetIRcode   ,  PBP, yes      ; call GetIRcode subroutine on Interupt
     INT_CREATE								; Creates the Interrupt Processor
    #HEADER
        ERRORLEVEL -306                     ; Suppress page boundry warning for DT_INTS-14 macro during a compile
    #ENDHEADER
     '----------- 16F1825  - PIC chip settings --------------------
        OSCCON   = $70         ' Select 8Mhz , internal clock
                            ' Bit 7 0 = 4xPLL disabled  1= 4xPLL enables ( overrided by conf word 2 setting -  PLLEN)
                            ' bits6-3 -  1111 = 16Mhz , 1110 = 8MHz or 32Mhz ( depends on 4xPLL - conf word 2)  1101 = 4 MHz, 1100 = 2MHz 1011 = 1MHz
                            ' bitS 0-1 - 00= Clock set by Conf word ,01 = Timer1 OSC , 1x = internal Osc Block
        APFCON0 = %00000000	'All Default - No change when using SPI  use SDO1 = RC2 , bit6=0
        APFCON1 = %00000000	'All Default  APFCON1 = %00000000
        CM1CON0 = $00 	        ' Disable / Clear comparator 1
        CM1CON1 = $00 	        ' Used with CM1CON0
        CM2CON0 = $00 	        ' Disable / Clear comparator 2
        CM2CON1 = $00 	        ' Used with CM2CON0
        CMOUT   = $00          ' Disable Comparitors output register - used only if comparitor on
        ANSELA =  %00000000    ' Set Port A - Digital I/O  , 0 = Digital  1 = Analog
        ANSELC =  %00000000    ' Set Port C - Digital I/O  , 0 = Digital  1 = Analog
        INLVLA = %00000000	    ' Set Port A to TTL Levels 0 = TTL , 1 = SCHMITT TRIGGER - Used port reads and Interupt on Change
        INLVLC = %00000000	    ' Set Port C to TTL Levels 0 = TTL , 1 = SCHMITT TRIGGER - Used port reads and Interupt on Change
        SRCON0 = %00000000     ' Disable Latched Outputs
        SRCON1 = %00000000     ' Used with SRCON0 register
        ADCON0 =  $00          ' Disable A/D
        ADCON1 =  $00          ' Disable A/D  - used with ADCON0 settings
        WPUA   = %00001100	    '  Port A - Turn off week Pullups 1=ON , for each port ( globle enable set in option_reg.7)set wpu on PortA.3 as input only - ref spec
        WPUC   = %00000000     '  Port C - Turn off week Pullups 1=ON   For each port
        DACCON0 = $00          ' Disable D/A
        DACCON1 = $00          ' Disable D/A - used with DACCON0
        FVRCON  = $00          ' Disable Fixed Voltage Ref
        IOCAN.4 = 1            ' Enable interupt on change on portA.4 for negative going edge  ( for getIR routine )
        IOCAF.4 = 0            ' Clear Interupt on Change flag on portA.4
        OPTION_REG.7 = 1       ' Weak Pullups disabled  1 = globel disable 0 = globel enable ( set by each port - WPUA & WPUC settings)
        OPTION_REG.6 = 0       ' Interupt on Falling Edge of INT pin  0= falling edge  1= rising edge
        OPTION_REG.5 = 0       ' TMR0 clock source - 1=T0clk pin 0=internal clock
        OPTION_REG.4 = 0       ' TMR0 0=L/H of TOCKI pin  1=H/L of TOCKI pin
        OPTION_REG.3 = 0       ' Use Prescaller for TMR0  0= Yes , 1 = No
        OPTION_REG.2 = 1       ' Timer0 prescaler Rate Select bits 2-0(set to 1:256)
        OPTION_REG.1 = 1       ' 000 = 1:2  , 001= 1:4  , 010 = 1:8   , 011 = 1:16
        OPTION_REG.0 = 1       ' 100 = 1:32 , 101 = 1:64, 110 = 1:128 , 111 = 1:256
        T1CON  = %01110100     ' Timer 1 ,bit7-6 = TMR1 CLK source 00 = Instuction Clk(Fosc/4),01 =sys clk,10=ext clk,11=cap sense osc
                            ' bit5-4 = TMR1 prescale 11= 1:8 ,bit3=0 LP off,bit2=1 no sync ext CLK ,bit1= 0 n/a,Bit0=0 Timer 1 on/off
        T1GCON = %00000000     ' Timer 1 Gate Control bit7 0= counts regardless of gate 1 = gates in use  , bit6 gate active when 1= High  ,0=low
                            ' bit5 0= toggle mode diabled 1= enabled  bit4 single pulse mode 1- en 0= dis, bit 2 -status bit,1-0 - gate source sel
        T2CON  = %01110011     ' Timer 2 off + 1:15 postscale ,1:64 prescale ( bit 7 = x, bit6-3 1110 = 1:15 postscale, bit2=0 timer off ,bit1-0 = prescale 10 = 16 , 11= prescale 64
        T4CON  = %00000000	    ' POSTSCALER 1/1,STOP,PRESCALER 1/1
        T6CON  = %00000000 	' POSTSCALER 1/1,STOP,PRESCALER 1/1
        TMR0 = 0               ' Clear TMR0 MODULE REGISTER
        TMR1H = 0              'CLEAR TMR1H MODULE REGISTER
        TMR1L = 0              'CLEAR TMR1L MODULE REGISTER
        TMR2 = 0		    	'CLEAR TMR2 MODULE REGISTER
        TMR4 = 0			    'CLEAR TMR4 MODULE REGISTER
        TMR6 = 0		     	'CLEAR TMR6 MODULE REGISTER
     'PR2 = 255              ' Timer 2 Preload value
     'PR4 = 255              ' Timer 4 Preload value
     'PR6 = 255              ' Timer 6 Preload value
  1. pbp and linux
    By Chirpy in forum mel PIC BASIC Pro
    Last Post: - 17th December 2012, 23:37
  2. Replies: 1
    Last Post: - 30th October 2012, 10:28
  3. Replies: 5
    Last Post: - 16th October 2012, 21:31
  4. Re: DT_Ints-18
    By Steve_88 in forum mel PIC BASIC Pro
    Last Post: - 4th March 2012, 19:39
  5. USB CDC with DT_INTS
    By MikeWinston in forum USB
    Last Post: - 26th March 2011, 02:40
