Message String Table using Readcode
Results 1 to 3 of 3
    mytekcontrols's Avatar
    mytekcontrols Guest
    Default Message String Table using Readcode
    I've tested the following code on the PIC18F series (I don't know if it will work on other PIC's).
    MsgBaseAddr var word
    MsgIdx var byte
    Msg_Ctr var byte
    Char_Ctr var byte
    ascii var byte
    ' Program Start
    'GetMesg Program Routine retrieves character string from Message Table
    'Format: "MsgIdx = X: GoSub GetMesg" (where X = 0 to last message in table)
    GetMesg:
    'Initialize counters
        Msg_Ctr = 0
        Char_Ctr = 0
    'Retrieve Message Table Base Address
    asm
        movlw  Low Msg_table
        movff  WREG, _MsgBaseAddr
        movlw  High Msg_table
        movff  WREG, _MsgBaseAddr + 1
    endasm
    'Locate beginning of message string and adjust base address to match
        While MsgIdx > Msg_Ctr                  ' When we have a match, exit!
        Readcode MsgBaseAddr, ascii             ' Retrieve character and
        MsgBaseAddr = MsgBaseAddr + 1           ' move index to next position.
        If ascii = 0 Then                       ' If at end-of-message...
            Msg_Ctr = Msg_Ctr + 1               ' Increment to next mesg string and
            If MsgBaseAddr // 2 = 0 Then        ' Determine end-of-string padding.
                MsgBaseAddr = MsgBaseAddr + 2   ' If Even #, pad 2 spaces
            Else
                MsgBaseAddr = MsgBaseAddr + 1   ' If Odd #, pad 1 space
            Endif
        Endif
        Wend
    ;Retrieve message and send it
    GetString:
        Readcode (MsgBaseAddr + Char_Ctr), ascii	' Retrieve character
        If ascii = 0 Then Return			' Leave if end-of-message!
    '---- your output code goes here (HSEROUT [ascii], LCDOUT ascii, ect) ----
        Char_Ctr = Char_Ctr + 1			' set pointer to next character
        Goto GetString
    ' Message Table
    ' Each string is terminated with a 0
    asm
    Msg_table
        DATA "message #0",0
        DATA "message #1",0
        DATA "message #2",0
        DATA "message #3",0
        DATA "message #4",0
        DATA "message #5",0
        DATA "message #6",0
        DATA "message #7",0
        DATA "message #8",0
        DATA "message #9",0
        DATA "message #10",0
    endasm
    Here is the format to call the above routine, in order to output the individual message strings:
        MsgIdx = 0: GoSub GetMesg
        MsgIdx = 1: GoSub GetMesg
        MsgIdx = 2: GoSub GetMesg
    In the section: "---- your output code goes here"
    You can do whatever you desire to fullfill your particular needs. For instance; In the following example, we add a carriage return and linefeed at the end of the message string, sending it all out the hardware usart (RS232).
    GetString:
        If ascii = 0 Then Exit			' Leave if end-of-message!
        HSEROUT [ascii]
        Goto GetString
    Exit:
        HSEROUT [$0D,$0A]
    Anything is possible, just use your imagination.
    Edit: corrected missing variable declaration for ascii
    Enjoy,
    Last edited by mytekcontrols; - 10th July 2005 at 23:05. Reason: forgot to declare variable
    Feb 2004
    Germany
    Michael,
    apart from the fact that you have missed to declare ascii VAR BYTE
    it works just fine on my 18F's
    That way I can probably get rid of an external EEPROM I was using for message strings.
    (presuming there is codespace left to store the strings)
    MANY THANKS!
    I'll do some further testing and let you know the results.
    regards
    Ralph
    mytekcontrols Guest
    Wink Oppps!
    Thanks Ralph,
    I fixed it.
    Depending on how you were doing this before, you might see a tremendous savings (especially true if you were using PBP's Table Lookup function).
    I certainly can't take all the credit for the idea, since much of this was made possible by looking at other people's code examples. However I do think my approach is possibly unique, since I have been looking, and looking for a solution like this for quite some time now, and never found anything exactly like it. I would be curious to know what other PICs this will work on, since all I use now-a-days are the 18F series, and have no easy way to confirm this.
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 12:53
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 10:38
  3. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 07:50
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
  5. PIC 18F452 Table Pointer/ Table Read
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 03:07
