I'm trying to start with just getting one timer to work and do the usual "Flash an LED", or actually toggle between 2 LED's so I can tell where in the timing sequence it is.  With what I have below, LED2 is on at startup and then it switches to LED1 and never toggles again.  I think I have something wrong in my setup but don't know what.  Once I get this working I would like to add the TMR1 (TimerB).
Any help is appreciated.
Thank you,
Hylan
Here's the code:
'*  Name    : TimerTest.BAS                                      *
'*  Notice  : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS] *
'*  Date    : 12/9/2012                                         *
#config
 __CONFIG _CONFIG1H, _OSCS_OFF_1H & _OSC_XT_1H
 __CONFIG _CONFIG2L, _BOR_ON_2L & _BORV_27_2L & _PWRT_ON_2L
 __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
 __CONFIG _CONFIG3H, _CCP2MUX_OFF_3H
 __CONFIG _CONFIG4L, _LVP_OFF_4L
#endconfig
'Interrupt code added 12-9-12
INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
INCLUDE "Elapsed_INT-18.bas"  ; Elapsed Timer Routines
        ;INT_Handler    RX_INT,    _serialin,   PBP,  no
        ;INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
        INT_Handler   TMR0_INT,  _TimerA,   PBP,  yes
        ;INT_Handler   TMR1_INT,  _TimerB,   PBP,  yes
    INT_CREATE                ; Creates the interrupt processor
T0CON  = %10010010             ; T0 = 16-bit, Prescaler 8
;@   INT_ENABLE   RX_INT     ; enable external (INT) interrupts
;@    INT_ENABLE   INT_INT     ; enable external (INT) interrupts
@    INT_ENABLE  TMR0_INT     ; enable Timer 0 interrupts
;@    INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
CLEAR   ' Clear all variables to 0
LED1        VAR PortC.5     ' Output 1
LED2        VAR PortC.4
IN1         VAR PortE.0     ' Input 1
Counter     var byte        ' Keeps count of seconds
PortA   =   %00100000       ' PortA All Off
PortB   =   %00000000       ' PortB All Off
PortC   =   %00000000       ' PortC All Off
PortD   =   %00000000       ' PortD All Off
PortE   =   %00000000       ' PortE All Off
PortF   =   %00000000       ' PortF All Off
PortG   =   %00000000       ' PortG All Off
TRISA   =   %00011001       ' Inputs = 1, Outputs = 0 RA(7-6) NA
TRISB   =   %11111111       ' Inputs = 1, Outputs = 0
TRISC   =   %10000010       ' Inputs = 1, Outputs = 0
TRISD   =   %11111111       ' Inputs = 1, Outputs = 0
TRISE   =   %11111111       ' Inputs = 1, Outputs = 0
TRISF   =   %11111111       ' Inputs = 1, Outputs = 0
TRISG   =   %00000000       ' Inputs = 1, Outputs = 0 RG(7-5) NA
ADCON0  =   %00000001       ' A/D Enabled, Channel 0 (AN0)
ADCON1  =   %00001110       ' AN0 Analog Input (Rest Digital I/O)
ADCON2.7 = 1                ' Right Justify 10 Bit Word
CMCON   =   %00000111       ' Both Comparators Disabled
INTCON2.7 = 0               ' Turn ON PortB Pull-Ups
T1CON   =   %00110100       ' 1:8 Prescale, T1OSCEN Off (524.288mS)
GOSUB ResetTime               ; Reset Time to  0d-00:00:00.00
GOSUB StartTimer              ; Start the Elapsed Timer
pause 200
if (Counter > 0) and (Counter < 10) then
LED1 = 1
LED2 = 0
LED1 = 0
LED2 = 1
goto Main
TimerA:
if SecondsChanged = 1 then
    SecondsChanged = 0
    Counter = Counter + 1
        If Counter = 20 then
        Counter = 0
@ INT_RETURN
