Hello everyone!
I'm trying to develop a basic queuing system, using 2 digit 7 segment. Currently I have 3 buttons to trigger a bell and increment the value display. So far the main functionality are working...but at the moment buttons are on PORTA. The problem I'm facing is when buttons are pressed long enough it continues to increment in which I do not want. My solution is to use DT's interrupt library, using external interrupt (on Pic18F4550).
For testing I use the following codes...
asm
    __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    ;__CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
    __CONFIG    _CONFIG2H, _WDT_OFF_2H
    __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
    __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
endasm
Define OSC 20
INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
TRISD = %00000000
PORTD = %00000000
Led1 Var POrtD.5
        INT_Handler    INT0_INT,  _ToggleLED1,   PBP,  yes
        INT_Handler    INT1_INT,  _ToggleLED1,   PBP,  yes
        INT_Handler    INT2_INT,  _ToggleLED1,   PBP,  yes
@   INT_ENABLE   INT0_INT     ; enable external (INT) interrupts@   INT_ENABLE   INT1_INT     ; enable external (INT) interrupts
@   INT_ENABLE   INT2_INT
  PAUSE 100
GOTO Main
'---[INT - interrupt handler]---------------------------------------------------
ToggleLED1:
     TOGGLE LED1
@ INT_RETURN
Works perfectly for my project...now my question is, I know PORTB has 3 external interrupt. Is there a way I can make the same functionality for 6 buttons? I've read some about interrupt on ANY pins but not really sure how to implement it. Hope anyone can give me an idea/help ..appreciate it very much.
Thanks in advance,
tacbanon
