How to create 6 buttons?
Results 1 to 11 of 11
    Jun 2011
    Philippines
    Default How to create 6 buttons?
    Hello everyone!
    I'm trying to develop a basic queuing system, using 2 digit 7 segment. Currently I have 3 buttons to trigger a bell and increment the value display. So far the main functionality are working...but at the moment buttons are on PORTA. The problem I'm facing is when buttons are pressed long enough it continues to increment in which I do not want. My solution is to use DT's interrupt library, using external interrupt (on Pic18F4550).
    For testing I use the following codes...
    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        ;__CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    Define OSC 20
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    TRISD = %00000000
    PORTD = %00000000
    Led1 Var POrtD.5
            INT_Handler    INT0_INT,  _ToggleLED1,   PBP,  yes
            INT_Handler    INT1_INT,  _ToggleLED1,   PBP,  yes
            INT_Handler    INT2_INT,  _ToggleLED1,   PBP,  yes
    @   INT_ENABLE   INT0_INT     ; enable external (INT) interrupts@   INT_ENABLE   INT1_INT     ; enable external (INT) interrupts
    @   INT_ENABLE   INT2_INT
      PAUSE 100
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    Works perfectly for my project...now my question is, I know PORTB has 3 external interrupt. Is there a way I can make the same functionality for 6 buttons? I've read some about interrupt on ANY pins but not really sure how to implement it. Hope anyone can give me an idea/help ..appreciate it very much.
    Thanks in advance,
    tacbanon
    Sep 2009
    Default Re: How to create 6 buttons?
    Here is example how to use 1 int to serve button on any input pin of PIC.
    One button also can be attached to INTX pin.
    In your ISR just look which pin is 0, then do whatever you want.
    If all pin is 1, then button on INTX is pressed...
    Jun 2011
    Philippines
    @Pedja089
    Thanks so much for sharing...got to try it...feedback here my output later.
    I have a follow up question, I've tried before to create a 4x4 keypad using Mr_e' s keypad routine...do you think the same concept can be applied to my 6 buttons?
    regards,
    tacbanon
    Sep 2009
    It probably could...
    Try to pull down all "drive line" And on the top of ISR scan whole keyboard... Then again pull down all "drive lines".
    You could still read the I/O in a Timer based ISR... done fast enough it "give" the feeling of an interrupt. You can even use the Time base as debounce delay... you could even trick the PIC and generate a false INT0 interrupt by writing directly to the according bit.
    No extra hardware needed, free up one I/O.
    Jun 2011
    Philippines
    Hi..something not right, I'm trying to toggle led on PORTB.7 but no success....can you check my code what I'm doing bad?
    asm
    endasm
    Define OSC 20
    TRISB.7 = 0
    PORTB.7 = 0
    TRISD = %00000000
    PORTD = %00000000
    LedD Var POrtD.5
    Led1 var PortB.7
    INCLUDE "DT_INTS-18.bas"        ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"      ' Include if using PBP interrupts
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
    @    INT_ENABLE   INT_INT     ;RB Port Change Interrupt
    PORTB = %00000000
    Toggle LedD
    GOTO Main
    ToggleLED1:
         'TOGGLE LED1
         If PortB.1 = 0 then
         Toggle Led1
         If PortB.2 = 0 then
         Toggle Led1
         If PortB.3 = 0 then
         Toggle Led1
         If PortB.4 = 0 then
         Toggle Led1
         If PortB.5 = 0 then
         Toggle Led1
         If PortB.6 = 0 then
         Toggle Led1
         Endif:Endif:Endif:Endif:Endif:Endif
    @ INT_RETURN
    thanks in advance
    tacbanon
    Check the default interrupt edge....that's not what you need
    INTCON2
    Jun 2011
    Philippines
    Hi mister_e,
    Thanks for the time responding...I think the default is INTCON2.6 = 1 so I need to make INTCON2.6 = 0 'interupt on falling edge.
    But either one for me is not working on my setup.
    regards,
    tacbanon
    Have you tried with real hardware or your life depends on How proteus decide to work (assuming it works at all)
    From your schematic you're using led instead of diode and i'm pretty confident proteus is not smart enough to understand this.
    Sep 2009
    Maybe problem is in D1 - D6.
    Check state of int pin when you press button...
    It square on INT0 should be blue if button is pressed...
    If that isn't case, replace D1 - D6 with 1N4148.
    Jun 2011
    Philippines
    Default Re: How to create 6 buttons?(SOLVED)
    Thank you pedja089 and mister_e...I got it now.
    /tacbanon
  1. 12F683 + buttons
    By sincity337 in forum mel PIC BASIC Pro
    Last Post: - 14th October 2010, 20:53
  2. Buttons
    By WarPony in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 02:47
  3. 6 Buttons
    By Johansch in forum General
    Last Post: - 4th July 2007, 16:21
  4. Buttons are driving me nuts
    By Doormatt in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2007, 00:09
  5. Latched buttons
    By peu in forum mel PIC BASIC Pro
    Last Post: - 25th January 2006, 01:22
