Hi - I gotta believe I'm overlooking something incredibly simple, but I give up and beg for help:
This is a simple 12F683 program. It's not finished yet, but I'm stumped at this early point. In the code below, as I emulate it in Proteus, when I execute the instructions "GPIO.5 = 0" or "GPIO.5 = 1" (indicated by the "***" comments), GPIO.0, which is high, goes low. I can't figure out why it should be affected by the GPIO.5 commands, unless I'm missing something in my register setups.
Anybody see what I'm missing here? Please help me to say "Doh!".
Thanks.... chico
  __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _PWRTE_ON & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
OPTION_REG = %00000000  	'Bit 7 = 0: Internal Pull-ups enabled via WPU.
WPU = %11111111 		' (Weak Pull Ups) 1=Internal pull-ups = on
INTCON = %00000000       	'Disable Interrupts
CMCON0 = %00001011	' Analog comparator: Comparator w/ Output and with Internal Reference CM<2:0> = 011
VRCON = %10001111    'VOLTAGE REFERENCE REGISTER: Enabled (b7=1), High Range (b5=0), Range (3:0)
TRISIO = %00011010 	' GP5: output to relay, GP4: not used, GP3: input MCLR, GP2:comparator output, GP1 voltage input,  GP0 output to LED,
ANSEL = %00000010	' Set GP1 to analog
ADCON0 = 0 		' A/D off
GPIO = %11111111        ' All outputs = high on boot
ControllerOutputPin 	var GPIO.5 		'Alias GPIO.5 to relay controller
LED				var	GPIO.0	' Alias GPIO.0 to LED
'********** PROGRAM SETUP ***********************
' Main loop checks for signal and adjusts ControllerOutputPin (GPIO.5) if necessary
' also creates slow square wave on DIAGNOSTIC OUTPUT pin (GPIO.0)
	if CMCON0.6 = 1 then 'COUT bit in CMCON0 register
' ***HERE'S THE PROBLEM. WHEN THE NEXT INSTRUCTION EXECUTES, BOTH GPIO.5 AND GPIO.0 GO LOW. WHY IS GPIO.0 AFFECTED BY THIS INSTRUCTION?
		GPIO.5 = 0   'same thing as "low ControllerOutputPin" or	"low GPIO.5" but uses less code
' ***SAME PROBLEM HERE. WHEN THE NEXT INSTRUCTION EXECUTES, GPIO.5 GOES HIGH BUT GPIO.0 GOES LOW. WHY IS GPIO.0 AFFECTED BY THIS INSTRUCTION?
		GPIO.5 = 1		' same thing, less code as:	high  GPIO.5	' ControllerOutputPin
'for testing:
	' toggle	LED
	if GPIO.0 = 1 then	'DiagnosticOutputPin
  	  GPIO.0 = 0           	' toggle diagnostic LED
	   GPIO.0 = 1		'high GPIO.0         	'Send continuous blinky
goto Main
