problem in serin2
Results 1 to 3 of 3
    Oct 2011
    Default problem in serin2
    Please i try to receive data from fsk ic ht9031 by 16f628a using serin2 command and display results on 7 segment ...my proplem is i dont receive any data exept when i use this command
    serin2 porta.0,813,300,loop[wait($02,$0a),idstring\10]
    Pecuse most nombers in my country are 10digits ...but another numbers are 9 digits and the main problem when i use
    serin2 porta.0,813,300,loop[wait($80),idstreing\length]
    I recieve rong data
    Default Re: problem in serin2
    Your PIC have a built-in USART... use it, it has load of of advantage.
    you haven't posted other lines of code, so it could be anything... often really simple like adding
    CMCON = 7
    at the top of your code... it already happen once here... maybe twice...
    Oct 2011
    thank you it is solved ......
  1. Problem with serin2 serout2
    By jasem700 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 19:55
  2. SEROUT2/SERIN2 Problem
    By thirsty in forum mel PIC BASIC Pro
    Last Post: - 11th September 2007, 06:56
  3. serin2 DEC problem
    By PortlandJohn in forum Serial
    Last Post: - 6th April 2006, 13:56
  4. Serin2 problem on 16F876
    By jrt4fun in forum mel PIC BASIC Pro
    Last Post: - 29th May 2004, 18:24
