Hi - I gotta believe I'm overlooking something incredibly simple, but I give up and beg for help:
This is a simple 12F683 program. It's not finished yet, but I'm stumped at this early point. In the code below, as I emulate it in Proteus, when I execute the instructions "GPIO.5 = 0" or "GPIO.5 = 1" (indicated by the "***" comments), GPIO.0, which is high, goes low. I can't figure out why it should be affected by the GPIO.5 commands, unless I'm missing something in my register setups.
Anybody see what I'm missing here? Please help me to say "Doh!".
Thanks.... chico
Code:#CONFIG __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _PWRTE_ON & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF #ENDCONFIG DEFINE OSC 4 OPTION_REG = %00000000 'Bit 7 = 0: Internal Pull-ups enabled via WPU. WPU = %11111111 ' (Weak Pull Ups) 1=Internal pull-ups = on INTCON = %00000000 'Disable Interrupts CMCON0 = %00001011 ' Analog comparator: Comparator w/ Output and with Internal Reference CM<2:0> = 011 VRCON = %10001111 'VOLTAGE REFERENCE REGISTER: Enabled (b7=1), High Range (b5=0), Range (3:0) TRISIO = %00011010 ' GP5: output to relay, GP4: not used, GP3: input MCLR, GP2:comparator output, GP1 voltage input, GP0 output to LED, ANSEL = %00000010 ' Set GP1 to analog ADCON0 = 0 ' A/D off GPIO = %11111111 ' All outputs = high on boot ControllerOutputPin var GPIO.5 'Alias GPIO.5 to relay controller LED var GPIO.0 ' Alias GPIO.0 to LED '********** PROGRAM SETUP *********************** ' Main loop checks for signal and adjusts ControllerOutputPin (GPIO.5) if necessary ' also creates slow square wave on DIAGNOSTIC OUTPUT pin (GPIO.0) Main: if CMCON0.6 = 1 then 'COUT bit in CMCON0 register ' ***HERE'S THE PROBLEM. WHEN THE NEXT INSTRUCTION EXECUTES, BOTH GPIO.5 AND GPIO.0 GO LOW. WHY IS GPIO.0 AFFECTED BY THIS INSTRUCTION? GPIO.5 = 0 'same thing as "low ControllerOutputPin" or "low GPIO.5" but uses less code pause 1000 else ' ***SAME PROBLEM HERE. WHEN THE NEXT INSTRUCTION EXECUTES, GPIO.5 GOES HIGH BUT GPIO.0 GOES LOW. WHY IS GPIO.0 AFFECTED BY THIS INSTRUCTION? GPIO.5 = 1 ' same thing, less code as: high GPIO.5 ' ControllerOutputPin pause 1000 endif 'for testing: ' toggle LED if GPIO.0 = 1 then 'DiagnosticOutputPin GPIO.0 = 0 ' toggle diagnostic LED else GPIO.0 = 1 'high GPIO.0 'Send continuous blinky endif ' goto Main END
