Check within a 16 bytes window
Results 1 to 6 of 6
    Default Check within a 16 bytes window
    Here is the problem.
    I have a counter that is 16 bits wide. Also another 16 bits counter.
    I need to check if the distance between them is no more that 16 bytes.
    The tricky part is where the one is near the roll over and the other has already rolled.
    For example one counter is at FFFC and the other is at 0003.
    Any ideas?
    Default Re: Check within a 16 bytes window
    IF ABS(count1 - count2) > 16 THEN ...
    Every time I get an answer by Darrel, I feel I have to hide somewhere... Embarassed.
    Thanks Darrel.
    Well, don't feel too bad, cause I'm not even sure that will work under all conditions.
    I should do some testing.
    After some testing ... it does work.
    Now I want to hide.
    I just did not think in terms of pure binary maths. So trying to find a way with 10 base mind was driving me away from the clear solution you gave.
    Thanks again.
  1. trying to do a scroll window
    By AvionicsMaster1 in forum Test Area
    Last Post: - 7th September 2011, 15:00
  2. Posts editing window is small
    By flotulopex in forum Forum Requests
    Last Post: - 14th April 2011, 11:20
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 15:36
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Time window
    By Franko in forum mel PIC BASIC Pro
    Last Post: - 9th August 2005, 17:42
